The Coleman Mach thermostat in my 5th wheel blows its 2 A fuse a couple of times today and am trying to figure out what is causing this. Please help. I am unable to get the furnace to run even with a good fuse in the thermoatat. When I bypass the thermostat to run the Atwood furnace (red tied to white wire). THe furnace blower comes on and the burner sounds it lights for 5 seconds and then goes out. 15-20 seconds later it reignites and goes out and continues to cycle -- the blower motor runs the whole time. Please help
  • benmorris460 Apr 22, 2009
    Rylee
    Could the short be coming from the furnace -- as the furnace is not working properly (this was the reason that I started in on the thermostat to start with.
    thanks
    Ben
    Brigadier General:
  • 8,619 Answers
Hi
Its blowing fuses because of short circuit inside the coleman mach or due to two wires being shorted with each other. You'll need to open up your thermostat system to look for the short circuit and also shorted wires.Please look at the service manual of your Coleman Mach thermostat---
Coleman Mach thermostat service manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 22, 2009
  • Rylee Smith
    Rylee Smith Apr 22, 2009
    Hi Ben
    It could be the furnace . You need to check the white wire i.e the furnace control wire from the thermostat furnace blower operates independently from sequencer or time delay in furnace.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Apr 23, 2009
    Hi
    Yes the short circuit can also be due to the furnace. There maybe be two wires shorted inside the furnance. You'll need to open the furnance and would need to inspect for shorted wires. If you are unable to find then use a multimeter. Please look at the service manual of your Coleman Mach thermostat for more details---
    Thanks
    Rylee
Brand new Coleman Mach 8 RV aircon worked yesterday but today blue on light just keeps flashing and no compressor working
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Nov 07, 2015 | Coleman Mach III Air Conditioner
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
Have atwood furnace and coleman mach thermostat and it would not shut off. I unplugged power to rv and had to hit battery disconnect so that it would stop.waited few minutes...turned on...heat would not...
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Apr 23, 2010 | Coleman Mach III Air Conditioner
Thermostat keeps blowing fuses
There is a short in one of the thermostat wires. The fuse is triggered on the low voltage side of the unit. Replace the wires.
Feb 08, 2010 | Coleman Heating & Cooling
Constanly blowing fuses in thermostat
u have a short some place jumping the fuse wreck the transformer controls good luck Tom
Jul 07, 2009 | Heating & Cooling
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
We have a 2000 Coleman Cheyenne pop up with a Coleman mach roof unit. We turned it on today at home and the fan blows but the heater doesn't heat up and the air conditioner doesn't cool. Someone said if...
The distance of the cord is a big deal, 10AWG Cord would be best for this situation. If you have a 50ft cord, make sure that the cord is not wound up on top itself as this can cause a drop in voltage and a spike in amperage. Is the compressor trying to come on at all? If not, then you may have a problem with the selector switch or the thermostat. If the compressor is humming for a few seconds and then stopping and then trying to come on again, it could be a problem with voltage loss. Anything below 98.5 plus or minus 10% is too low the for the compressor to kick on.
Jun 06, 2009 | Coleman Mach 15 Air Conditioner
Coleman mach chill grill - heat turns on whether we have it programed or not. have heat off, ''I feel'' off, can be 80 outside we can be gone and come back to 110 degrees inside and heater on. When it...
Sounds like you have a bad thermostat or a short in the wiring. The clicking that you are hearing in the ceiling is a relay in the control board. When this happens, remove the face plate from the thermostat and check for 12VDC between the Blue and the White wires. If there is power then you have a bad thermostat. If there is not power there, then the problem is elsewhere. However, it sounds as if you have a bad thermostat.
Jun 03, 2009 | Coleman Mach 15 Air Conditioner
Thermostat
Several things cause fuses to go. But you ace in the hole is that it works for sometime before it goes out. This suggests that a relay or contactor is not pulling in as it should. I would try replacing the fan relay (if so equipped) and definitely the compressor contactor. If either of these try to pull in and are off center internally the result can be blown fuses intermittently.
DO NOT GO ABOVE 5 amp fuse or you may burn out the transformer.
The other things that can cause a blown fuse intermittently where your describing (although less likely unless subject to rodents and or high or low voltage spikes)
1 a temporary short in the control wiring (wire to or from the thermostat).
2 A short intermittent on the control board (if so equipped)
3 A relay on the control board or the SS circuitry is not operating with in design parameters.
I would really like to know what you discover the problem is.
If this helped you understand your system or problem please rate me as high as you can and thank you for using fix ya. Good Luck.
Mar 27, 2009 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
377 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
