Question about Toshiba Satellite A65-S1065 Notebook
Toshiba satellite a65-s1762 dvd-ram drive problems
Hi, My laptop reads some cds and others not. I recently installed WinXp SP2. In resume i insert for example a warcraft 3 cd and the cdrom led stays on, i double click the DVD_RAM drive in my computer and says it is not accessible because of an I/O error. Then i insert another cd i burned with some programs and it reads fine.Then i insert another cd i burned and i get the same error. And once again i insert another cd i burned that contains linux and it reads just fine.
I also cant read any dvd, i have the following messages:
Please insert a cd.
Device not accessible.
Incorrect function.
So i decided to test the cds that gave me errors on another computer just in case, and guess what... they worked just fine.
Any advices?
    Brigadier General:
  • 10,406 Answers
Take the laptop *and* your DVDs/CDs to a qualified technician.
It seems like the drive is "intermittently" failing, and needs to be replaced.
Posted on Apr 23, 2009
Do not know the bios password on toshiba satellite a65-s1762. Cannot contact the guy I got it from since he passed away.
Hi
Remove the battery from the motherboard.
Try google to find exactly the location for this battery
Leo
Apr 17, 2011 | Toshiba Satellite A65-S1762 Notebook
I want to replace the hard drive in my toshiba satellite A65-S1762
Easy. Your HDD is located in front of the battery pack - to the side. The door is held in by one screw, and the HDD is held to a bracket by 2 screws. Any 2.5", 9.5mm height ATA IDE drives will do. Make sure you don't lose the door, bracket, and screws.
Dec 22, 2009 | Toshiba Satellite A65-S1762 Notebook
I need drivers for my toshiba laptop satellite A65-S1762
Just google the site of Toshiba.com and the they provide drivers you want .
Good luck;
Regards;
VOTIT
Dont forget to rate:
Jul 03, 2009 | Toshiba Satellite A65-S1762 Notebook
How to install additional toshiba a65 s1762 memory
Yes, you need to flip your laptop over and look for a removable compartment that requires you to unscrew a screw. Once you get the cover removed, you will see slots with either one or two memory modules installed. If one is installed, then you can add the additional memory module in the empty slot. If you have 2 already installed, then you will need to remove one and install your new module, which would only give you a total of 768 megs. Just slip the new memory in and press it down towards the motherboard and start your laptop..
May 16, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satelite A65-S1762 hard drive problem
That means that the disk has a bad sector.
Try chosing the option to format the hard drive during the system installation.
If that does not work, then replace the hard drive.
Nov 16, 2008 | Toshiba Satellite A65-S1762 Notebook
Satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A65-S1762 makes one long beep then two short when turned on
Sounds like video problem.
My wife has one of these and it died.
One file came up corrupt and then after I restored it the system would just drop power without warning.
Then would hang in safemode at an ATI sys file for the video.
It's on the mainboard. These also have built in RAM problems too.
You can try to remove any additional RAM you may have added in the bottom slot and try to boot.
My best advice is get a $20 best buy/staples 2.5" USB HDD enclosure and throw the HDD in there and toss the leftovers on Ebay with an explanation.
You'll get $100-150 for it to help buy yourself a new one.
Sell the LCD as one deal, the keyboard another, AC adapter another and so on. You'll get more that way.
I'd go Fujitsu. Toshiba used to be good but they went to **** to compete with HP/Compaq and sell at Walmart.
Gateway is also decent. The key is newer laptops run too hot and end up toast in a year or two.
Buy something a little less frantic in the GhZ dept. and it will last longer.
Pushing a laptop for gaming or 3D graphics is hardly it's best use. Manufacturers are too busy adding flashy selling points instead of practical features like lighter weight and longer battery life.
Aug 14, 2008 | Toshiba Satellite A65-S1762 Notebook
Toshiba A60-DVD rom doesn't read
You may not have a DVD burner... I would agree with Sun.
Apr 28, 2008 | Toshiba Satellite A60 Notebook
CDROM drive does not read some CDs
best and most affordable solution - replace the cdrom drive.
Sep 23, 2007 | Toshiba Satellite P15-S479 Notebook
Toshiba Satellite A65-S1065 Notebook Logo
200 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
