Question about Craftsman Saws
Mcgill lock switch on my Craftsman bandsaw, Model 113-247410 does not work. Where can I get a new switch? Craftsman said it is discontinued. It is red plastic, with a yellow locking key.
  • 2,176 Answers
You can go to Searspartsdirect.com and on the right side of site type in your model number and look under base for this item. Most of the parts for your tool appear to be obsolete no replacement but I did see a couple types of switches still available. If I have helped would you please rate the information as you see fit and Thank you.
Posted on Apr 22, 2009
    Problem Solver:
  • 16 Answers
Rowdy your suggestion is great and is exactly what I did but although I used the part # in the users manual what they sent me was not the same switch. I'm going to try to retrofit but just so others know..if you purchase a part from sears direct be advised they don't always match even if you use their part number from the users manual! BJ
Posted on Jun 19, 2009
I need a replacement switch for a craftsman saw model # 315.11860
Seems to be an old saw and many parts are discontinued
Sear lists it but Switch is not available.
craftsman saw 315 11860 parts Google Search
Dec 15, 2017 | Craftsman Saws
I am Looking for a miter gauge (which is an accessory) for a old craftsman model 113.244512 band saw. Is there any around out there?
You may look up to ebay or search on google. I actually order band saw parts with www.bandsawparts.com but I think they don't have the miter gauge for your bandsaw model.
Dec 20, 2012 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Feb 15, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Ooking for a copy or manuel for a Craftsman bandsaw model 113.247
I am sure there is one to download but did not found anything with google...
If search engines are no help, just ask some deep web specialists, e.g. manualfox.com - this is a manual search agency and if they don´t find it, it does not exist in the Internet.
Aug 31, 2009 | Craftsman Saws
Craftsman radial arm miter saw parts discontinued
Any hardware or home improvement store will have a replacement.
Jul 22, 2009 | Craftsman Saws
Saws Logo
723 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
