Question about Mitsubishi WS-65713 65" Rear Projection HDTV
Green blinking light
I have a Mitsubishi WS-65713. The green blinking light comes on randomly at times and will not reset. I have tried everything from callin the help line in the owners manual, unplugging, etc.. The last time this happend it took 12 hours to reset where we could watch it. Does anybody have a clue on the cause? It is plugged into a Monster surge protector. Randy
  • Anonymous Nov 16, 2007
    I had ths problem with the blinking green light on the 65" Mitsubishi. The first guy had it two weeks and could not repair it. The second guy fixed it on the spot. He specialized in Mitsubishi repair. It was the (4) capastors all the time. Price--$285.00 total. Anyone having this problem with the TV not turning on and the green light blinking should have a Mitsubishi expert fix it. Not a run of the mill big screen repairman. I was without my TV a total of 3 weeks when it could have been much sooner had I listened to everybody on this site who said it was the 4 caps.
    Randy
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Posted on Sep 23, 2007
  • Lashawn Robinson Sep 25, 2007
    Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
Mitsubishi WS-65713 Blinking green light. TV will not turn on!
These Mits TV's tend to have power supply problems that are well documented on the web, when the symptom is as you describe. And this assumes no other unusual noises were heard before the TV went into shutdown.
The repairs are fairly straight forward if you are comfortable with electro-mechanical dis-assembly, soldering repair, and re-assembly.
Just do a search on Mitsubishi (your model number) and capacitors.
Dec 21, 2009 | Mitsubishi WS-65713 65" Rear Projection...
TRY TO GET TO THE MENU, SETUP, AND EDIT YOUR SETUP SO EVERYTHING IS DEFAULT. I TOOK A 2001 50" HOME LAST NIGHT, MY SLEEP TIMER LIGHT ON THE FRONT, BLINKED FOR A FEW MIN. THEN, YOU CAN TURN IT ON AND RESET.....HOPE IT HELPS.......????
Dec 07, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Green light blinking
Diane,
I do not have the service manual but have instructions with pictures. Will email them to you. If you have never soldered check look for instructions on utube and with some practice you will be able to de-solder and solder. A utube video that is great is at http://www.youtube.com/watch?v=I_NU2ruzyc4. Good luck.
Oct 06, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi TV WS-65713
mine is doing the same thing. It started when I unplugged it to move to a new location. Can some one please help me!!!!
Sep 19, 2008 | Televison & Video
The DM module in the TV is bad. Some can be fixed easily some cannot. What is the model #?
Sep 11, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Capacitors on DM Module
I just fixed the capacitors on my WS-65713. I can email you instructions with pictures if you wish. You will need to de-solder and solder on new capacitors but if you check out video instructions on utube you should be okay with some practice.
Jul 29, 2008 | Mitsubishi WS-65713 65" Rear Projection...
I had the same problem and just fixed it. You likely have 4 bad capacitors in your DM board. To fix you will have to take the DM board out of the TV, de-solder the ones on there and then solder on new capacitors. For those who would like instructions on this leave me your email and I will email them to you. I can't believe I was able to do this but thanks to Jaime for giving me the instructions and checking how to solder on Utube. No I had never soldered before guess it shows you can do it with some effort.
Jul 10, 2008 | Mitsubishi WS-65713 65" Rear Projection...
you can get the service manual and detailed instructions on that repair by going to the following link.
http://servicemanuals.vstore.ca/
May 31, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Mitsubishi TV
I thpught I sent this to you already?
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
Mitsubishi WS-65713 65" Rear Projection HDTV Logo
160 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
