Question about Whirlpool Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
During wash and spin cycle the tub does not move. All other features of the washer seem to work such as water filling and emptying out but tub never moves. I can hear humming sound like a motor but that's it. What might be the problem and what part is more than likely need replacement?
  • ajaymess Apr 22, 2009
    Thanks! I will try that?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Posted on Apr 22, 2009
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
How do i fix a Whirlpool stylemaster 4217141 REV A whose cycle is not completing and that will not spin the tub or drain.
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Aug 02, 2014 | Whirlpool Washing Machines
Whirlpool duet dispenser to tub hose keeps cracking/ripping. why?
carefully check the position of the clamp, as the tub moves around during the wash and spin cycles the ears of the clamp been rubbing through the hoses
May 12, 2014 | Whirlpool 8540063 Washer Hose, Dispenser...
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Sep 22, 2009 | Whirlpool Washing Machines
Clicking noise when the washer is in the initial wash cycle,
does agitator or tub move at all during the cycle. if no movement then this sounds like the coupler. used in place of belt in this design, located between motor and transmission.
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Spinning doesn't take place during spin cycle
One possible problem is the door interlock switch. This switch prevents spinning when the door/lid is open. If the switch is bad (open/off all the time) it sends a false signal that the door is open and washer will not spin.
Does the machine just sit there when it's not spinning or does it sound like it's trying to spin but can't?
Apr 21, 2009 | Washing Machines
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
770 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
