After years Adobe Photo Deluxe 2.0 will not open. I added more ram and now when I try and open Adobe it tells me I don't have enough RAM to open. Frustrated!!!!! It is the only photo program I have
I have been using Adobe Photo Deluxe 2.0 program for years. It is the only photo program I have that actually lets me size all the way down to 1 X 1 if I want it. I added more ram to my computer and switched to Trend Micro...those were the only changes. Now when I try to open Adobe it tells me I don't have enough RAM to open it. I have uninstalled it and re-installed it and the same thing happens. What is wrong???
I had the same problem and an angel sent me this instruction and I solved it. Hope it works for you as well:
Start
-Control Panel
--System
----"Advanced" tab
-----Performance: -->Settings
------"Advanced" tab
-------Virtual Memory: -->Change
--------"Custom Size: (change it to) Initial: 4000MB Maximun Size: 4095MB
----------Set
-------------OK everything out
***Restart your PC
Posted on May 14, 2009
WOW THANKS DONGBLACK IT WORKED ON MY VISTA FOR PHOTOSHOP DELUXE Business edition 1.0!!!!!!! I love this program and will always use it!!!! Thanks to you!!!!
Posted on Feb 09, 2010
I have a Toshiba Satellite A200 24A. The videos that I run from YouTube and other such sites do not run smoothly. They are jerky/choppy. What could be the reason. Please do not tell give me complicate
Anytime your streaming videos are playing but not running smoothly, you either have a slow internet connection and aren't downloading fast enough to keep the data streaming OR you don't have enough RAM to keep up with the streaming data and everything else that's going on in the background. Check your internet connection speed first. If you have a good download speed then add RAM to your pc. (You could also try clearing cache on your browser)
Jun 13, 2012 | Toshiba Computers & Internet
Adobe Photo Deluxe 2.0 and windows 7 (x64) Adobe Photo Deluxe 2.0 and windows 7 (x64) Hi everybody. I am trying to install Adobe Photo Deluxe 2.0 on Windows 7 (x64) but I am not able. I tried to follow...
I do not believe this is possible. Adobe now makes 64 bit only programs since coming out with Creative Suite 4 and Photoshop. If you have 7 Professional or better, you can download Microsoft Virtual Machine and Virtual XP SP3 machine free (Microsoft.com) and install Photo Deluxe in the virtual machine.
VirtualBox is another free one.
Sep 23, 2011 | Acer Computers & Internet
The graphic adapter doesn't have enough resources to run properly.
You might need to upgrade your RAM I don't know how much you have but adding more would probable solve your problem If you go to www.crucial.com and run there scanner it will tell you how much you can add the type and amount the MB supports you can also buy it from them , RAM mod gels are easy to install you will see some vertical slots next to the CPU fan they will be put into those slots the RAM will have notches in them and you just line those up with the ones in the ram slots and press in until the locks on ether end locks it in
Aug 31, 2011 | HP Touchsmart IQ524 PC Desktop
Asus p5ld2 deluxe ranlike a champ until I added 2 additional 1gb sticks of RAM itbeeps whenthe power is turned on but will notboot
it doesn't like the ram obviously,
  • 240-pin DDR2 DIMM Banking: 4 (2 banks of 2)
  • Chipset: Intel 945P
  • DDR2 SDRAM Frequencies: PC2-4200 and PC2-5300
  • Error Detection Support: Non-ECC only
  • Graphics Support: PCI Express x16
  • Max Component Density: 1024
  • Max Unbuffered DDR2 SDRAM: 4096MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR2 SDRAM only
  • USB Support: 2.x Compliant
  • make sure you installed the correct speed of ram, secondly if the ram speed is correct take out one sitck at a time, and try to boot, it's possible that one is bad from factory.
  • Jan 01, 2011 | ASUS P5LD2 Deluxe Motherboard
    Adobe PhotoDeluxe does not run with Vista
    I found this solution on another forum and it worked for me. I have Adobe Photodeluxe 4 on a vista OS and got the same RAM error. I tried the "change the virtual memory" fix and that did not work. Then I found this: Right click on the Adobe Photodeluxe icon on the desktop and choose Properties, click on the Compatibility tab and choose run this progam in Windows XP service pack 2 mode. It worked for me!
    C
    Aug 10, 2009 | Microsoft Windows Vista Ultimate Edition
    Problem adding Additional Ram to my Asus A8N SLI DELUXE system
    Just because BIOS is recognizing the RAM doesn't necessarily mean it is usable. Also, ASUS recommends that you have the same amount of RAM in each bank. Another point they make is that your motherboard does not support double-sided DIMM chips.
    I would refer to the manual for their specific instructions on proper RAM configuration:
    http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI%20Premium/e2435_a8n-sli_premium.pdf
    If you are concerned that the memory stick might be bad, swap it out with one of your older ones, and see if your system boots and performs as it should. If not, then you know it is bad. My guess is that if you populate the memory slots with 4 gb, the system will recognize and make all of it available to you.
    Cheers
    Nick
    Jan 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
    Unable to Open
    I'm sorry but the only way you're going to be able to use CS2 is if you either use less programs on the computer so that you can open it without the error message coming up, or downgrade back to Photoshop 4.0 or buy more RAM for your computer. Adobe Photoshop requires quite a bit of RAM so really, it would be wise to upgrade if you want to continue using their products.
    Oct 09, 2008 | Adobe Photoshop CS2 for PC
    ADOBE PHOTODELUXE 2.0 NOT ENOUGH MEMORY???
    I purchased a new computer which was Vista..It also told me the same thing. I deleted it because I knew I had the memory..I did that 3 times then finally it worked..
    Mar 17, 2008 | Microsoft Windows Vista Ultimate Edition
    Go into the PhotoDeluxe2.0 CD ROM file list, right click on setup.exe and then go to the compatability tab. Select Win 98/ME. Hit OK. Then double-click on setup.exe. Program should install on Vista. Then find setup.exe on your hard drive, and set the compatability to Windows 98/ME. Program runs, but says something about not being able to load 16-bit driver. Just cancel out of that popup window. Program works fine...for me...so far.
    Feb 02, 2008 | Microsoft Windows Vista Ultimate Edition
    Start up
    try it without the new ram and see if the problems go away- might just be incompatable ram.
    Nov 20, 2007 | Compaq Presario Notebook
    Computers & Internet Logo
    276 people viewed this question
    David Payne
    David Payne
