Question about Garden
Lawn mower won't idol at a high enough speed
The lawn mower idols at a very low speed and i can't seem to find the idol screws
  • 82 Answers
How old is it? Some newer models have a set idle and can't be adjusted
Posted on May 09, 2009
My mower stopped making left turns
Kinda not normal. Your question is hard to understand, but i will give some kind of answer as to what I think you are saying. make sure the throttle stays at full or high speed. I'm assuming that this is a GAS rotary mower. also make sure the cable going down the handle does not move.
Jul 20, 2014 | Toro Lawn Mower With Toro Power Tools
96 yz250
If it consistently shuts down when it warms up you are probably losing ignition. It sounds like you have a weak ignition coil. There is two or three different adjustments you can make to the carb. Idol speed, low speed mixture screw(pilot) and high speed mixture screw(main jet) If you can get a good vid of the carb I can direct you
May 02, 2013 | Motorcycles
I have a briggs engine model 282h07-0196e1 . the engine will not run at high rpm
Hi your governor spring is probably broken, it connects the throttle plate to the throttle shaft assembly. regards Phil
May 30, 2012 | Garden
Have a 1992 toyota corolla 3 speed auto, that shakes when stopped at a stop light, and when you take off it runs fine. changed plugs cap and rotor and still does it..
Check your engine idol. It could be that your idol speed is set to low. It should probably run at between 800 and 1000 RPM. If it is not then your idol is to low.
Jan 03, 2011 | 1992 Toyota Corolla
My idol screw needs 2 b ajusted 2 factory settings
No you are confusing the idle screw (a thumb-screw) with the air/mixture screws, these are turned inwards (clockwise) until they lightly seat & then back out the specified amount
You should have the bike tuned by a professional who should include synchronising the carbs, this will let the engine run more smoothly, idle at lower revs ,increase speed & all-round performance speed
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
Apr 24, 2010 | 1989 kawasaki ZXR 400
I have a 1990 chevy truck, it Idols high - low in town
You may have an Air Idle Solenoid and or Idle Speed Motor. Not familiar with you vehicle. Check that out.
Apr 15, 2010 | 1990 Chevrolet K1500
Craftsman model 358.791042, gasoline weedwacker wont stay running
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
High idol all the time& tranny problems
Check for vacuum leaks on the high idol. You have a speed sensor or wiring issue with the tranny. Will need to be checked somewhere with a computer to know for sure on the tranny.
Jun 08, 2009 | 1994 Chrysler Concorde
Reving too high dosent idol
If the mower is reving up and down it sounds like a carb issue it most likely needs rebuilt and adjusted I would also change the air filter on it after you get it repaired to help keep the carb clean.
Feb 26, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Idol problems
the idle screw can be located by following the throttle cable to the carby body, you will find a quarter wheel which the cable hooks into at the bottom you'll see adjustment screw, this will adjust your idle speed.
Jul 13, 2008 | 2000 Ford Focus
Garden Logo
240 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
