Question about Vehicle Parts & Accessories
I don't know the security code to reset the radio on my 2001 vanetta cargo van, after changing the battery
Mine is posted in the glove compartment
Posted on Apr 24, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How to reset engine service light
Suggest auto parts store many of them will do a complementary check. They have in the past connected a scan tool and reported the error codes for their customers..
Another has been for some error codes disconnecting the battery for about a minute or more and reconnecting has reset the codes. Suggest after reconnecting the battery not to apply any throttle pedal for the first few minutes. The PCM electronics will need to relearn the running data.
Nov 28, 2015 | 2001 Econoline Cargo Van
When i changed ignition on 2001 ford explorer I ended up having to replace steering column now it wont turn over & the anti theft light flashes & wont stop. what can be done to get car started?
At least you know the anti theft system is working. Jokes aside, I would think that the electronic security system is not recognising the new lock and steering column. You could try leaving the battery completely disconnected for at least 2 or 3 hours to see if the system resets. Reconnect the battery and then try again with the new key. You will have to put the security code back into your radio as well. If this doesn't work, it may need to go to a Dealer to reprogram your electronic system.
Apr 13, 2015 | 2001 Ford Explorer Sport
Why wont radio work after replacing battery?
by replacing the battery the anti-theft code requirement has been activated
check the radio forums and comments on this site as there are ways to recover the code
Jul 25, 2017 | 2001 Chrysler Town & Country
Hi! i changed the battery of the car, when i did it i lost the code of the radio and now i don't know the code... if u can please help? the car is audi a6 2001 1.8
When the battery was removed the codes are reset and so it will be best to check your manual or the dealership database as this is easily available with them.
If not check if the following link gives some tips:
http://www.radio-code.com/
http://www.floodle.net/extra/ebayinfo/car_radio_decode.html
Aug 11, 2011 | 2002 Audi A6
2001 dodge grand caravan sport.Grandkids left light on and killed Battery. Jumped the van got it started notice this morning going to work my Radio and speedometer isnt working.Checked fuses but none...
Make sure to check the engine compartment fuses and the inside fusebox, if all the fuses look good then try to unhook the battery and then connect it back on and start the van and see if this helps. the radio is it asking for a code, if this radio has antitheft then you will need to install the code to make it work, look at manual and it will tell you how to do this. the code is entered using the preset staition buttons, there should be a card in the glovebox with the radio code if it has antitheft. if you find no bad fuses then you may have short out the cluster jumping it, but most of the time it just needs a fuse or reseting by removing neg battery terminal for about 2min, good day let me know the outcome.
May 09, 2011 | 2001 Dodge Grand Caravan
Just changed the battery on my 2001 Chevy Suburban and now the radio displays LOC. I assume this is some sort of anti-theft security. Anyone know what the code is to reset the radio?
I have seen this alot. The best advice I can give on this is take it to a local Chevy dealer and MOST of them will put their code in for free.
Aug 10, 2009 | Car Audio & Video
2001venture van service engine soon light stays on
most any sensor going bad can cause the check engine light to come on,try disconnecting the posative battery cable for 15 seconds ,then put it back on,will reset the codes, or take it to auto zone,they will test your computer for codes at no charge to you.i had a venture van my was ox. sensor. thanks robert b.
Jun 16, 2009 | 1998 Chevrolet Venture Cargo
2001 Buick radio Locked after battery change
Most likely there is an anti-theft code for the radio and you must enter that code to enable the radio. This will happen when the is battery is disconnected. If you do not know the code or the procedure for entering it consult your manual. If you do not have the manual or code you will need to have the dealer reset it for you.
Apr 10, 2009 | 2001 Buick LeSabre
Battery died in 2001 astro van....
Some models of the astro were equipped with the security feature like your describing. If the radio is locked (meaning it doesn't work at all) it will be the security. Seems funny that the radio wouldn't work, but usually it locks it too. As far as I know, youll have to go to GM and have it unlocked.
Jan 15, 2009 | 2001 Chevrolet Astro
Vehicle Parts & Accessories Logo
97 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
