Question about Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger
I need a side view and top view on a kabota loader R420S prefarably a black and white scketch style drawing.
  • 469 Answers
Posted on Apr 22, 2009
I have a kabota m6060 tractor 2016 My hydraulic pump out put is 1100 gpm,I need 1500 gym to use a rotro mower front loader.?
contact your Kabota dealer , we have no idea what might be wrong with the system
Dec 19, 2017 | Garden
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
18 hp kabota diesel is blowing black smoke at start up
Does the Kabota have glow plugs? Or just compression start?
If glow plugs, let plugs warm a little longer before starting.
Jan 09, 2013 | Cars & Trucks
Wiring bath fan with Fan/ light combo. Want to operate the features on seperate switches. Have power wire Black/ White/Green. Each switch has own wire Black/White/ Green. In the unit there is a Blue/white...
If I understand correctly you are installing two wall switches.
Your switches are switch1 and switch2
Each switch has 2 brass-colored screws
If you have a double switch, see page bottom
And you are installing a fan/light combo with separate wires for fan and light.
Bare ground wires and green wires connect to each other and to green screw. A ground wire runs from fan/light to switch box where it connects to other bare copper wire and these wires will not be discussed.
Lets work from the fan/light down to the switch.
Blue-wire-fan connects to either brass screw on switch1
White-wire-fan connects to white Neutral (we'll talk about this wire as we go)
Black-wire-light connects to either brass screw on switch2
White-wire-light connects to same Neutral as White-wire-fan.
So you need 3 wires running from fan/light to your switch box.
One wire arrives at switch box and connects to brass screw on switch1
One wire arrives at switch box and connects to brass screw on switch2
One wire is the Neutral wire and it arrives at switch box and connects to other white wires inside switch box. Twist these wires together and cover with wire nut.
Now your white Neutral is connected to other white wires in switch box.
Each switch still needs another wire.
The Hot black wire from breaker box connects to brass screw on both switches
Pardon the crude drawing.
The switches would actually be located next to each other, but it was easier to draw like this.
Drawing shows 3 wires coming from fan-light to switch box.
The drawing shows the black and white wire arriving from breaker
The drawing does not show how the white wires are joined with a wire nut
If you have a double switch, with 2 switches stacked vertically.
The screw colors can be different.
Double switch could have brass screws on both sides, in which case your Load (fan-light) wires connect on one side of device, and your Hot from breaker connects to other side. It doesn't matter which side, but loads on one side, hot on other side.
Double switch could also have dark screw(s) on one side and brass screws on other side.
In this case, the black Hot from breaker connects to dark-colored screw(s)
And your Load (fan-light) connect to brass colored screws.
If you need more information, or if something is still confusing, answer back.
Oct 26, 2010 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Tiny leak at front of machine
Is this a FRONT LOADER? Or, a TOP LOADER?
The following link explains how to access and inspect the interior of a FRONT LOADER and what common sources of leaks to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of front loader leaks comes from the door bellow (gray rubber seal). A routine inspection around the perimeter of the door for rips or tears will tell if the bellow needs replaced. If the bellow requires replacement, the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If this is a TOP LOADER, the following link explains how to access and inspect the interior for common sources of leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The most common source of leaking on a TOP LOADER is the drain pump. These pumps are not serviceable and if found to be leaking, need to be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Whatever style washer you have, make sure you read through the links provided and follow the steps on how to properly access your washer interior so you can get an accurate view. Make sure you check all tub seals, dispenser hoses and drain hoses as well.
Replacement parts (if required) can be purchased from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jun 22, 2010 | Washing Machines
Washer is leaking from under machine checked all hoses and drain connections and there were no leaks in them.
repairclinic.com
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Jun 08, 2010 | Washing Machines
Why is my tv only showing black and white when I hooked up my new converter box?
It decided you needed to view tv old school style. I had this problem, turn the tv on after you turn on the converter box. That solved it for me.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Need help with my Calypso Whirlpool top loader washer
The drain is located on the bottom in the back towards the right side. Pull out machine and lean it back. Remove 2 or 3 screws holding block bottom panel and let it drop. The drain pump will have 2 hoses going to it and is prorbably grey in color with 2 black clips holding it on. If it looks like this, then it's the original pump. Should be replaced with the new style where the pump is actually part of the pump motor. I work on these OFTEN and the original pumps are NO GOOD.
Mar 20, 2009 | Washing Machines
Broken switch on top loader
new style (on top under console) clips in with lid up, old style screws in from side (those frequently break)
Mar 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger Logo
104 people viewed this question
Top Heavy Duty Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Heavy Duty Electrical Supply Expert? Answer questions, earn points and help others
