Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Wd and Seagate usb hard drives attached to computer Will not boot when WD usb hd on Seagate makes no difference
  • 702 Answers
Check the drive letter assignment for the disks, and make sure it is not the C: driver.
I am assuming you can boot and then plug the disk, right?
So use the Disk Manager to check the driver letter, and change it if it is conflicting with another disk.
Jules
Posted on Apr 23, 2009
I put 140G photos in my 500G WD element external HD. Now it is very slow and some files cannot be copied. What is the good way to get the data back? Thanks.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Windows vista cannot detect my wd 320gb element external harddisk
* the USB cable
* the power-adapter
Dec 11, 2010 | Western Digital Elements powered by WD 320...
Windows wil not start with wd external usb hd 1.5t , if pluged after windows starts up everythings ok
Your system boot order may be USB first before then the internal Hard disk. So during system boot your system tries to boot from the USB which has a drive attached to it and since the drive is not bootable the system will stop. When you remove the drive the system will boot from the internal hard disk. This is normal just remove the USB and plug it after the system loads the windows files.
Jun 02, 2010 | Microsoft Computers & Internet
My computer hangs when I start it up until I remove the WD 320 GB External USB connection - then it will restart ok. I have to then reconnect the hd. - what can I do about this?
It sounds like it is trying to boot from the external drive, go into the BIOS settings and disable boot from external device and see if that cures it.
Mar 30, 2010 | Western Digital Elements powered by WD 320...
Wd portable hd - device attached to this system is malfunctioned
It could be that the Hard Drive inside the enclosure still works, not sure if you care about voiding any warranty as opening it up will likely do, but there is a very slight chance that the Hard Drive itself will let you get the data off it. I am not sure what the connector to the drive is on the inside though as I have not taken one apart myself, :).
Sep 09, 2009 | Western Digital WD Passport 250GB Portable...
WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | Western Digital Passport WDXML800UE...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Sabrent 5in1 USB-DSC5 doesn't recognize 2.5" WD hard drive
I have had a different problem with this product. But, I have read many postings on its problems. It seems that for certain hard drives the jumper should be set for something other than 'master', either CS or no jumper at all. This seems to be true for only certain HD's.
Hope this helps.
Scott Bolton
Mar 18, 2009 | Sabrent (USB-2535) (USB2535) IDE...
After software install of the new HD my computer will not boot if the HD USb cable is left attached. If I unplug the USB cable then the computer will boot up.
please check the boot priority in cmos setting...if its 1 priority given from usb drive than it will not boot till u unplug it.
Apr 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
220 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
