Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
No display under 1024x768
If I try to set the display down to 800x600 the screen just goes gray. if i try to play any games they just stop and go to desktop. i have a SVA VR-17S and a ATI Radeon 8550 AGP video card. everything works great with my old CRT monitor. I just don't get it.
  • hweeksjr Apr 22, 2009
    the refresh rate is set at 60hz.
I have the same problem with 800x600. I've found that by setting the refresh rate to 56 Hz, I can get the games to play. For instance Age-Of-Empires II only works with this method. My old monitor worked fine, and this works at 1280x1024.
Posted on May 02, 2009
  • SVA-USA Master
  • 3,866 Answers
The monitor itself needs repair when it cannot display within its normal values, the logic board the controls the refreah rate has gone or you need to change your refreash rate on your video card and make sure its in the same threshhold that your monitor supports- Thanks
Posted on Apr 22, 2009
The letters are grainy using the data projector
Try changing your setting s on your computer to match the resolution to your projector. Change display settings to 800x600, 1024x768, etc. with your mouse right click on your screen, click properties, at the display properties dialogue box click the settings tab you should see the screen resolution.
May 31, 2010 | Sharp Notevision PG-B10S Multimedia...
How to get windows to display black borders?
Shame you didnt tell us what the game is as you may be able to find a later model of this game thats been modified for use in high end PC's.
I do not know of a setting that can do that......have to keep altering the res.
Apr 30, 2010 | Dell Latitude D600 Notebook
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I just installed hasbro classic game collection on pc i have a 19" widescreen aoc monitor and when i try to play monopoly i can not see the whole picture it is like it is long and narrow and the game will...
before you start your game, you can try to modify your screen resolution and then start the game it will fit to the new screen size.
depending on your OS (winodws)
WIN XP close all windows and place your mouse over your desktop right click and select properties. a windows will pop out with the following tabs THEMES, DESKTOP, SCREEN SAVER SETTINGS.
click on settings and you will see a computer screen(s) and it will be a place to change the SCREEN RESOLUTION (800x600) (1024x768) etc try a diffrent one from the one you are using and click apply and then OK. run the game, if it persist just try a different size.
WIN VISTA click on desktop area and sellect PERSONALIZATION, click on Display settings and change the RESOLUTION.aplly and ok.
if my advice was of any help please rate me :)
thank you
Oct 07, 2009 | AOC 22" Widescreen LCD Monitor
Can't install f22 LII on vista home,
I'm playing F22 on XP with dosbox. It should work in vista.
It's a dos emulator
Feb 25, 2009 | NovaLogic F-22 Lightning 2 for Windows
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Can't view videos full screen on samsung syncmaster 2232 bw plus
Make sure your video setting are not at 800X600. Goto your display properties and then settings. Put your screen resoultion to 1024X768. try that
Aug 10, 2008 | Computers & Internet
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Aug 05, 2008 | Computers & Internet
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Sharp XR10X Screen size
depending on the age of your computer, some of the older video cards in XP only will allow you to show video in 600x800 resolution. When you want to show video go ahead and change both of your display properties (both the primary and the secondary) to 600x800. See if that works.
If that is not what you are refering to go right click on your desktop and look for the properties or settings of your graphics card. it may say graphics properties . In that area there will be tons of options like (when showing video only show it on the secondary monitor) play around with the different settings on your graphics card.
Good luck
Feb 28, 2008 | Sharp XR-10X Multimedia Projector
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
237 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
