Question about Vision Panini My X 60 Check Scanner
Numbers on the back of scanned checks.
Some of my documents have numbers on the back and some don't. I want numbers on each document. Why is it missing putting numbers on some of the documents.
I have a uniden bearcat model#bc 55xlt
Posted on Apr 23, 2009
How can your fax machine on your canon pixma mx397 work? steps please.. thanks!
For details check Canon Pixma Mx397 Manual. Turn on your your printer. Press "FAX" button from printer. Load the document you want to fax on platen glass. Customize scan contrast and resolution settings as you need. Use numeric numbers to dial receiver telephone number. Start sending. You document will be faxed successfully.
Aug 03, 2013 | Office Equipment & Supplies
Minolta cs pro 1031f error CE 034566
Could not find that in the service manual But might be the main board. Will it scan if the document is placed on the big glass instead of the document feeder.
Jul 16, 2013 | Minolta EP1031/1031F CS/PRO Copier
Problem with section numbers not being linked in a word document that I'm updating using word 2007. The original document was created with an earlier version of Microsoft word.
When you create or open and edit a (.docx) document in Microsoft Word 2007, the Save As option gives you the opportunity to save it as a the (.doc) document in the formats of older versions of Word.
If it is not already too late, try to recover (using the AutoRecovery function built-into Microsoft Word 2007) , the earliest and most error-free version of the document in question you can recover and then use Save As, rather than Save to make an experimental copy of the document in an older Microsoft Word format.
Another option to consider is to download and install the free Office Suite Application Open Office, which can open, edit and manage many Microsoft Office documents and then copy and paste the most error-free version of the document in question into the appropriate Open Office Program and then see what sort of job the Open Office Word Processor makes of handling the tricky formatting.
For the future, as a general rule, whenever editing any document that contains complex formatting, always remember to start by copying and pasting the text of the original document into a new blank document (remembering to close the original document so you don't accidentally toggle between the two). Then your experiments could be conducted on a copy of the document, rather than the original, enabling you to repeat the method and continue creating experimental copies freely, until you have developed a workable strategy for dealing with the formatting issues.
Furthermore, remember to always use the Save As function, giving the experimental documents distinct and varying names (test.doc1, test.doc2, test.doc3 etc.) so you can keep track of your progress in mastering the formatting issues, then each document you save, is a copy, leaving the original document unchanged and available as a template for further experimentation, if necessary.
Nov 26, 2011 | Microsoft Office Professional 2007 Full...
Unable to open word document attachment in e-mail. Shows a square with numbers inside.
If you're seeing a little square with numbers inside (probably 1's and 0's) that file isn't a Word document at all, it is a BINARY file, an executable program, probably a virus or trojan.
Test the file with your anti-virus program, or better yet, simply DELETE it. Since you don't know what program it is, there is no reason to open it and risk damaging your system.
Feb 11, 2011 | Microsoft Windows XP Professional
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Faxing multiple recipients
The fax software on your computer should let you enter multiple numbers to fax to.  Scan the document to an image file on your computer.  The computer will store the image and will dial each number and send the document.
Nov 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Is there a way to program it to fax to a group of numbers at one time
You can use the "Broadcast " feature to send one fax to up to 112 numbers listed in your speed dial. To set this up:
  1. Insert the original into the ADF.
  2. Press Quick Scan/Reports. The display should show how much memory is available.
  3. Enter the One-Touch or Speed Dial numbers for the recipients you want to send to (one after the other). You can also setup a group dial number.
  4. Press Fax Start. The machine will scan the document into memory and then dial all the numbers you've entered. If any are busy it will attempt to redial.
  5. Press Stop/Exit at any time to cancel the broadcast.
If you need further instruction on how to setup group or speed dial numbers, Brother provides the user manual online.
Hope this helps!
May 15, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
NUMBERING A COPIED PAGE FOR COURT PURPOSES
WHILE VIEWING THE DOCUMENT ON THE COMPUTER DO THE PAGE NUMBERS SEEM TO BE CORRECT? IT COULD BE A DOCUMENT CODE ERROR. SOMEWHERE DURING YOUR CORRECT PAGE NUMBERING IS SOME UN-NEEDED TYPING THAT IS THROWING THE REMAINDER OF THE DOCUMENT OUT OF WHACK. ARE YOU USING WORDPERFECT? IF SO, TURN ON THE REVEAL CODES AND CAREFULLY GO THROUGH THE DOCUMENT TO LOOK FOR EXTRA SPACES, UN-NEEDED TABS, ETC. THAT SHOULD PUT THE DOCUMENT BACK IN ORDER. TIM
Jan 29, 2007 | Xerox Document Centre 255 DC Printer
267 people viewed this question
Top Vision Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
