Question about Motorola Mobility MOTONAV TN20 GPS Receiver
Unit no longer displays secondary roads, how can fix this?
  • 62 Answers
Go to GPS' .com site and download new maps.
Posted on Sep 13, 2009
Unit powers on but no display and no sound
It sounds like power supply problems which by design supply a multitude of what's called "secondary" voltages which are often different values...18volts, 24 volts, etc. A fuse blown on the primary side (or unit unplugged from wall outlet) kills ALL voltages where-as secondary voltages route through different circuits where some are obviously intact (unit still powering on) but other voltages have failed. It's repair shop time Robert.
Mar 31, 2015 | Audio Players & Recorders
GE Dryer model number dcvh515efww display not working
you could try removing the top of the unit, disconnect the display from the main wiring loom and reconnecting it, or try and buy a spare one and fit it.
Jul 17, 2012 | GE DCVH515EFWW Electric Dryer
While in route, if on major route, it switches to back and secondary roads. Even when I know it's a direct route, it doesn't want me on there
Check your map routing settings, if you have it as avoid major highways then it will avoid major roadways and take you on secondary roads.
Sep 25, 2011 | GPS
Km2030 showing code c610
C610 Broken fixing heater wire
• Warm-up does not end within 90 s.
• The secondary stabilization fixing
temperature drops to 100°C/212°F or
below.
• The fixing temperature remains below
40°C/104°F for 7 s or longer after the
fixing heaters have been turned on.
Causes
  • Fixing heater installed incorrectly (Check and reinstall if necessary.)
  • Broken fixing heater wire. (Check for continuity. If none, replace fixing heater.)
  • Poor contact in the fixing unit thermistor connector terminals.(Check the connection of connector CN12 on the main PCB and the continuity across the connector terminals.Remedy or replace if necessary.)
  • Broken fixing unit thermistor wire.(Measure the resistance. If it is ∞ ?, replace
    the fixing unit thermistor.)
  • Fixing unit thermistor installed incorrectly.(Check and reinstall if necessary.)
  • Fixing unit thermostat triggered.(Check for continuity. If none, replace the
    fixing unit thermostat. Check the operation of the cooling fan and repair if necessary.)
Jul 09, 2011 | Kyocera KM-1505 Copier
Windows Vista x64 Extended monitor flickers
hi you could alter the resolution for the projector and see how that goes
Mar 25, 2010 | Microsoft Windows® Vista 64-bit Business...
Windows 7 x64 Extended monitor flickers
right click on the projector an click on the properties tab
click on compatibility tab
tick the box and click on win 7---apply and ok
if it worked on win xp and you changed to win7 and doesn't work indicates a compatibility problem or driver for it in win 7
Apr 06, 2017 | Linksys EtherFast 10/100 16-Port Workgroup...
LMS 332c Power cycles on own
i've repaird this by installing a secondary powerswitch and disconnecting the power switch on the keypad. It's an involved repair but it can be done.
Jul 13, 2009 | Lowrance LMS-332C GPS Receiver
Power but no display to unit
Not sure about the Neff brand, but in general you'd want to check for 110VAC power on the primary side of the low voltage transformer on the control panel / board. If that is present, check the secondary for voltage, about 12-30VAC. If the unit has a VFD type display, there will be a heater filament supply, usually around 2.5-6VAC. Also look for bad connecitons on the VFD. If those voltages are present, check connections on the board, look for bloated / bulging capacitors, shorted diodes, breaks in the board, etc. Also look for thermal cutouts and thermostats. If this doesn't fix it, can you take several photos of the inner parts and circuit boards?
Sep 26, 2006 | Neff H7871A2GB 800 Watts Convection /...
Motorola Mobility MOTONAV TN20 GPS Receiver Logo
89 people viewed this question
Top Motorola Mobility GPS Experts
Will Halftowaite
Are you a Motorola Mobility GPS Expert? Answer questions, earn points and help others
