Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Minnkota trolling motor prop removal
Minnkita 35, s.n mkjf0252664 what's the trick? i have a minn kotta 24pnd trolling motor there is fishing line in between the propeller and the motor how do i remove the propeller?
  • 4 Answers
Remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
Posted on Apr 30, 2009
    Problem Solver:
  • 10 Answers
Open a pair of pliers about 3/4-1" and put on either side of plastic nut thing, and turn the prop clockwise while using the pliers to hold the nut still.
Posted on May 31, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    My minn kota endura 55 is three years old is making a grinding noise when in operation..
    I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
    Cost me around $85 at the local marine mechanic...
    May 22, 2011 | Minn Kota Endura 55 42 In Trolling Motor...
    How to remove the prop
    there is a plastic nut that screws onto the prop shaft and needs to be unscrewed. there is also a metal pin that goes through the shaft that needs to be in place and in the right position when you replace the prop. make sure you clear out any fishing line etc that may have collected behind it when you change props.sually recommend you put a little clear silicone grease on the parts as you assemble them as well.ake sure you disconnect the power leads from the battery while your doing this to avoid injury.
    May 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn kota
    Hello bombiegano. I suggest you check you wiring terminals. They could be corroded. If you have good connections next would be fising line, string or weeds jammed in rotor of your prop motor. If these suggestions fail please inform me of Mgrf.,model & serial# & we can repair the unit. Good Fishing.
    Oct 02, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Model 35 24lb thrust transom trolling motor not getting power
    It might help to view drawings at http://secure.northlandmarine.com/MinnkotaTillerSteering.html.
    The spring loaded items are brushes. They carry current to the rotor/shaft/impeller causing them to spin. I have two Model 35s. One failed after a couple hours of use. The other was given to me because it did not work. Both suffer from water getting into the motor and causing corrosion and sticking brushes. Someone on another site commented that this was a common problem for Minn Kota.
    Jul 17, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
    2,413 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
