Question about Dishwashers
Elite Kenmore dishwasher stopped working
My Ekite just stopped working. Lights stay on but no action. Then a flood let loose and had to turn it off. Any help will be appreciated
  • 213 Answers
SOURCE: kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Posted on Nov 28, 2007
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
Posted on Jan 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a kenmore elite dishwasher 577-9 17262402.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Need the model number of the Kenmore Elite dishwasher 1378(2)
The model number will be something like 110.123456
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite dishwasher Options light up but nothing runs.
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
My Kenmore Elite dishwasher just hums when we start it.Its not starting and no water is filling up
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Aug 09, 2010 | Kenmore Dishwashers
My Kenmore Elite 15919001 just stop working from one day to the next. It just seems like a fuse blew because I have no power to the dishwasher. None of the buttons work on the front board. Help!!
yes, it sounds like a fuse, or a circuit breaker tripped, or, if it is a plug-in connection, it may have come unplugged(outlet usually under sink. Might also have a loose connection in dishwasher connection box ..CAREFUL HERE;VOLTAGE MAY BE PRESENT!!!
...IT MAYBE THE DOOR IS NOT FULLY PUSHED IN TO ENGAGE SAFETY SWITCH
Feb 21, 2010 | Kenmore 15919 Built-in Dishwasher
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite - Flooded bottom
this is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Nov 19, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Kenmore elite dishwasher not running
I had the same problem with mine. The whole circuit board, buttons and all, need replacement. If you look online, you can find this part for a bit over 100 dollars. Definetely worth it over paying 5 bills for a new one.Simple to install too, just turn off power at breaker.
Jun 20, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
