Question about Jenn-Air Ventilation System for Custom Hood Installation, JXT7036A
What size duct do I need
Need to moove 1500 CFM of Air over a distance of 75ft with four 90's before fan. There is another 20ft with two 90's after the fan. What size duct Is needed? Ducting is spiral, galvanized steel.
Currently ducting is 12" with a 3/4hp tube fan. I feel duct and fan are just too small to move this amount of needed exhaust that distance.
Are there online calculators for this? Thanks, Ryan
    Top Expert:
  • Jenn-Air Master
  • 49,191 Answers
There are online formula to calculate what you want
google ---formula to calculate air flow in pipes--
calculation will have to allow for the turbulence and restriction caused by the spiral construction of the tubing and the bends involved so you may have to incorporate several formulas to get the desired result
distance is critical as there are frictional coefficients to be considered as well
I would consider from large shop air circulation systems (as you see in Aldi, woolworths , sears etc ) that a staged diameter difference from motor to exhaust point be considered as that will keep a steady air flow for the length of the tube and a hp rating of 3hp 3 phase as a minimum
Talk with the engineers of shop and factory air conditioner designers and installers to get a close idea to what would be suitable for you
Posted on Aug 03, 2017
3 Suggested Answers
  • 171 Answers
SOURCE: Jenn-Air Downdraft ducting roof Rack w/flapper
Hi Snowflow,
I'm Harvey the Master Plumber.
Your problem is: You are looking for a high quality roof mounted termination vent cap for 8" O.D. round ducting for your Jenn-Air downdraft Stove Top/Convection oven. The reason for the 8" ducting is that you are using insulated stove piping out of the wall of the house into a cold porch then up through the roof. You have come across a Broan Vent Cap that will accommodate 3-1/2" by 10" rectangular ducting and/or 8" O.D. round ducting. The problem with this Broan unit is it has an aluminum flapper that has no counter resistance mechanism to keep from readily flapping open and shut during weather related wind events. Is there something better out there? You found us through a Jenn-Air link. Help!
An 8" B-vent cap should work fine. Can be purchased at any plumbing supply. Just make sure you attach it with screws.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 14, 2008
go to www.luxurymetals.com
there are many good high quality vents on the site
Posted on May 26, 2009
How do I convert the CFM output to tonnage? Thanks much!
CFM is air flow, a product of fan size and speed and duct size, opening sizes etc.. The tonnage of the unit has no bearing on airflow.
Apr 01, 2015 | Cfm Heating & Cooling
I have a 2013 Brisk air 1500 ducted A/C. The problem is after several hours of cooling the fan will shut off but the compressor will continue to run (humming) After shutting of unit at thermostat and
sounds like the fan over heat, you may want to check the fan relay and wiring for corrossion and capacitor as it may not be shorted but lower in value and making the fan over heat and triggering its build in safety cut off..
Jan 06, 2015 | Brisk Air Heating & Cooling
Noise on high speed
Is it the original size motor? It sounds like it could be to many CFM for the size of the duct causing back pressure when the blower goes into high.
Apr 08, 2014 | Goodman Manufacturing Goodman MBVC2000AA...
Can not connect to the internet...Model LC40iF60CN...iSymphony
you say all other appliances in the house are working fine, my first thought to your question was that 75ft is too far to pick up a wireless router, are all the other aplliances the same distance away. ( i would recomend about 15 - 20ft ). hope this helps,
Aug 02, 2012 | iSymphony 40" Class 1080p 60hz LCD Smart...
If I change my unit size from a 2 ton to a 3 ton do I need to change the size of the ducting
You will perhaps need a bit of a change as the new unit will most likley deliver more cfm. But the contraqctor should be able to guid you on this.. get any changes in writing But it could be as simple as a transition duct change..
Aug 09, 2011 | Heating & Cooling
How to properly size a duct return in a house
To size that return duct you need to know the cfm of the unit, and size according to that...Ell's and distance also need to be factored in....
Here is a free duct calc. that you can use to help you size you ductwork...
Here is a website that will let you get a free trial duct calc.
http://efficientcomfort.net/Calculators.html
Here is another free duct clac...
http://duct-sizing.downloadsoftware4free.com/
Heatman101
Sep 21, 2010 | Coleman Heating & Cooling
Want to vent gas cooktop from top of ceiling cabinet down to basement and out chimmney. Distance is approximately 20 feet with four 90 degree angles. Suggestions? Thank you.
There are special fans that are used for this. Use the web to look up exhaust fans. Normally used for boilers, tumble dryers where the distance required to run is further than the fan supplied with the item can push it. The fan will need to be wired in so that the gas cannot be turned on until the fan is running. Pick the fan that best matches flue diameter, temp, and distance
Oct 04, 2009 | Cooktops
Calculation of CFM discharge from an opening of a duct collar
There's a thumb rule in A/C air distribution. At 1 TR load, the air supply is about 400 CFM and the ideal diffuser size is 16" x 16" with an effective flow area of about 70%. Branch duct size for this outlet should be around 12" x 12".
Jun 20, 2009 | Carrier Heating & Cooling
Size of vent pipe
You will be fine with 2 bends in an 8 inch pipe. If you bend it more than 3 times though you will loose fan force. If you up to a 10 inch duct you will not have good fan force because the space is bigger.
Good Luck and Please Rate FixYa!
Feb 25, 2009 | Fantech Fan FG8XL
Jenn-Air  Ventilation System for Custom Hood Installation, JXT7036A Logo
901 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
