The servers have taken over my printer without authorization. Nobody has access control to my PC OR PRINTER.I have not aothorized anyone permission. I DON'T SHARE my username or password with anyone to print too. Nevertheless,the servers use my printer and make an extra copy for themselves everytime I print out WHY? P lease check them out i'll be very grateful.
    Brigadier General:
  • 3,614 Answers
follow this few steps to disabled your printer in sharing into the network.
In WinXP,
  1. right-click Start and choose Explore.
  2. Scroll down the left panel,
  3. right-click My Network Places,
  4. and choose Properties.
  5. Next, right-click your primary network connection, which may be called something like My ISP, and select Properties.
  6. Click the Networking tab and look for File And Printer Sharing For Microsoft Networks in the middle list. If it isn't listed, click Install, Service, and Add. Deselect File And Printer Sharing, then OK. Once File And Printer Sharing appears in the list below the Networking tab, make sure its checkbox is unmark in it (click it if it doesn't) and then click OK.
hope this initial info/idea helps.
just let me know for further assistance.
thank you
Posted on Apr 22, 2009
How to use toshiba e232 printer without ****
Without a print enabler (this allows you print through the network), the only option is print through the USB port, Want to be able to print by anyone in the network, share printer with a host PC via USB, or use a net print server (via USB).
Oct 21, 2011 | Toshiba Office Equipment & Supplies
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Factory reset brother nc 2010h
Same problem, did you find a solution ?
Pascal
Nov 11, 2009 | Brother (NC-2010H) Print Server
I have a problem with a printer which is connected locally to a pc (comp1) on the network. I can access it from one pc but can not access from 3 other pc. I have three printers locally connected and...
Hi Shueb,
First off, I assume if your running a network, you'd have a server based product running. If so, I would have the server manage the printer as a shared printer. This can be accomplished by setting up the share either in your management console or your active directory. Then the server will administer the rights to the printer. If your running a network with just workgroups, then you will have to right click the printer and go to share and security. From there go to permissions and make sure that the users on those machines have permission to access it.
A real easy way to connect a shared printer on a network is to browse through the entire network icon, and click on the machine that is sharing that printer, and when you see the printer right click it, and go to connect printer, and that's it. As long as you've got all the drivers for all the different OS's on the differnent machine, it will install the driver and give you access.
Good Luck,
Mark
Jan 15, 2009 | Computers & Internet
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
Can I connect the printer directly to my laptop using ethernet cable
Hi! If the computer is connected to an HP All-in-One on a network, you can access the Embedded Web Server that resides in the HP All-in-One. The Embedded Web Server is a web-based user interface that provides some options not available on the HP All-in-One control panel, including advanced network security options. The Embedded Web Server also enables you to monitor status and order printer supplies. For information on how to use the features available in the Embedded Web Server, see the onscreen help within the Embedded Web Server. To access Embedded Web Server help, open the Embedded Web Server, then click the Help link under Other Links on the Embedded Web Server Home tab. NOTE: Only use the Embedded Web Server to change network settings if you cannot access the HP All-in-One control panel, or you need to change an advanced option not available on the control panel. Access the Embedded Web Server Use the following instructions to access the Embedded Web Server. You can only access the Embedded Web Server on a computer that is connected to an HP All-in-One on a network.
  1. Press Setup on the HP All-in-One.
  2. Press c00706174.gif until Network is highlighted, then press OK . The Network Menu displays.
  3. Select View Network Settings menu, then press OK .
  4. Select Print Network Configuration Page , then press OK . A configuration page prints, including the IP address. You will use the IP address in the next step.
  5. In the Address box in the Web browser on the computer, type the IP address of the HP All-in-One, as shown on the network configuration page. For example, http://192.168.1.101 . The Embedded Web Server Home page displays, showing information for the HP All-in-One. NOTE: If you are using a proxy server in your browser, you might need to disable it to access the Embedded Web Server.
  6. If you need to change the language displayed in the Embedded Web Server, do the following:
    1. Click the Settings tab.
    2. Click Select Language in the Settings navigation menu.
    3. In the Select Language list, click the appropriate language.
    4. Click Apply .
  7. Click the Home tab to access device and network information, or click the Networking tab to access more network information or to modify network information.
  8. Make any configuration changes.
  9. Close the Embedded Web Server.
Good Luck!
Oct 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
Printer server, wireless, detached cable now won't print
It is because the WiFI connection is more than likely on another IP address ie: Cable:192.168.0.1 type thing. WiFi:10.1.1.1 Type thing... so ya have to configure ya access and point ya printer in the right direction, so reinstall ya printer & driver and when it asks where the network printer is, point it to the correct address of the router's port..
Aug 08, 2007 | NetGear WGPS606 (WGPS606NAR) Print Server
21 people viewed this question
k24674
jasbo
jasbo
