Question about Refrigerators
Sometimes there are black particles (looks like black flakes) in the ice from my icemaker. Do you know what is the likely cause for this? Thanks
  • 490 Answers
Put a filter in the water supply line going to your ice maker more than likely it is rust from the inside of the water lines
Posted on Apr 22, 2009
  • raddie Sep 26, 2010
    this happened to me also. its the coating (paint) flaking off the inside. you can scrape/clean the
    loose coating inside or just get a replacement unit. (i did)
The ice from my ice maker has small particles in it that look like flecks of paint or metal. I have stainless bottom freezer Kenmore with ice/water in door.
To assist ice from popping out of the frozen mold of the icemaker it is coated with nonstick teflon,just like the teflon on your cookware.That teflon is flaking off of the icemaker mold and the icemaker must be replaced.All you need to do to replace it unscrew it from the side freezer wall,unplug it and instatll new one. The part number is 4317943 you could purchase it at your local appliance parts store on online at;
searspartsdirect.com
repairclinic.com
apdepot.com
assuredparts.com
appliancepartspros.com
Gene
Aug 05, 2011 | Kenmore 73503 Stainless Steel Bottom...
I purchased a GE profile refrigerator in 1996 so I'm not sure if you can help me. The problem I'm having is with the icemaker...the ice is coming out with rust and black specks on it. I have tried cleaning...
without bea able to visualy isspect it
i would say from experiance alone check the ice wells on your ice machine
at this age sometimes they tend to flake a bit
the ice amchine can be replace reletivly easy
usually about 10-30 mins work depending on model and
dexterity
usually two screws and a single wire clip
Oct 22, 2009 | Refrigerators
My whirlpool ice maker makes ice but it builds an ice dam and ice cicles on the back of the unit.
there might be a crack in the mold of the icemaker. you can unplug the fridge and take out the icemaker. there should be three 1/4" screws holding it in place. visually inspect the icemaker mold the see if its cracked or flaking. if it is, the icemaker needs replacing. hope this helps.
Oct 21, 2009 | Whirlpool Refrigerators
Amana side by side
Undissolved minerals can appear when ice cubes are added to chilled drinking water. Freezing tap water causes dissolved minerals to solidify and scatter, giving a cloudy appearance. When ice cubes melt, any undissolved minerals settle to the bottom. These mineral compounds in our drinking water are naturally occurring and safe.
Sometimes we see black particles which can be the non-stick surface of the ice mold flaking off.
Sep 07, 2009 | Frigidaire FRS23R4A Side by Side...
My U-Line ice maker somehow leaks water inside the freezer and a layer of ice builds up on the bottom below and to the sides of the ice container. It continues to build until ice container is not...
You can have a couple of things causing this. First do you see flakes in the ice cubes? Yes replace the icemaker. No then I would remove the cover off the icemaker (pry on the corners and pull) Check to see if the motor gears is rusty. If yes then its causing the motor to run slow and overfillilg the icemaker. You can also check to make sure the fill tube is pointing downward in the water cup of the icemaker. If that looks goo then it cold be the matter of replaceing the faceplate of the icemaker. That would replace the switch, motor and gears.
Aug 16, 2009 | U-Line Icemaker
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
Water leaks out of ice making trays with making
What model is this? Is the unit leveled? DO you have flakes in the cubes? Is the fill tube pointing downward> there should be a clip that holds the filltube down. If all this is ok then remove the cover of the icemaker. Is the gears corroided? If so then I would recommend to replace the faceplate. This would change the motor 2 switches and the gears. Part #150 should fix it.
If your getting flakes then you need to replace the icemaker. If the fill tube clip is missing then you will need to replace this.
Jun 28, 2009 | U-Line Icemaker
Dirty ice
Hi, Remove the ice maker and look at the tray the cubes are made in. You will probably find the casing is flaking off. All you can do is replace the icemaker.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Refrigerators
Water leaks inside unit wher selenoid calls for water
The fill tube that goes into the water cup of the icemaker make sure its in with a clip on the cup to hold it downwards. Sometimes the clip is off and the tube sprays out of the icemaker. Also check to see if flakes are in the ice. That would mean that the teflon is peeling off and forcing the water out of the icemaker.
May 09, 2009 | U-Line Refrigerator Ice Maker
Ice Maker has some black stuff in water
check the ice-maker itself, it has a teflon coating (like a frying pan) that sometimes flakes off leaving little black flakes in the ice. if this is the case you have to change the ice-maker.
Jun 28, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
370 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
