Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Kenmore gas oven
I keep getting a f2 vault code, does anybody know what this is and how do i fix it?
    Problem Solver:
  • 7 Answers
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Posted on Aug 11, 2009
F2 error when oven is turned on. keeps beeping. appears the oven isn't working properly. Gas over/range
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Kenmore Ovens
Error Code F2 and F3 on Kenmore free standing stove model 71342
My Magic Chef oven keeps getting a F3 error
Dec 14, 2009 | Kenmore Ovens
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
EO -F2- Error?
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Oven
F2 is aproblem with the oven sensor part number WB21X5301
Mar 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F2 error code
Intermittents are a real problem. My first guess: look around for a corroded or damaged electrical feed. Could be electrical noise from that. Not sure what No other possiblities other than a bad panel. I don't know what F2 is.
Dec 06, 2007 | GE JGRS14 Gas Single Oven
Kenmore electric oven
F2 typically means an overtemperature condition. The cause could be welded relay contacts,a stalled or blocked cooling fan, blocked air flow to the rear of the unit or high resistance in the oven sensor leads or connectors. Check to see if there is any accumulation of dust bunnies in the fan. Do you remember if the fan has been running? There could also be a bad thermal switch. This tells the fan when to turn on and off. Unless you have some technical expertise, you may not feel comfortable checking on some of these causes. Be sure and turn off the power before poking around the wires and connectors in the top of the oven. There is usually a sheet of trouble shooting instructions in the top section of your oven which will give you some assistance. Good Luck.
May 09, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Apr 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
99 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
