This problem should be removed because:
Problem with Standard Televisions
rca f38 310
My RCS F38310 is out of fucus, bright and large picture with white lines running across the screen. Is anyone else having the same problem? What can be the problem? What needs to be done to repair the TV?
Solutions (1)
This sounds like the Extremely High Tension (EHT or high voltage) is too high. This is supplied to the cathode-ray-tube via the sucker-like terminal clipped to the side of the CRT as in all conventional tube TV's
There is an adjuster but to set it correctly requires a voltmeter that goes up to 30,000 volts or more.
The chances are that the regulation of the power supply has gone wrong.
One other thing, not wanting to alarm you, if the EHT really is too high then the TV will be producing more X-ray emission but it will be a only be a small amount more.
The EHT needs setting properly to bring the emissions within acceptable limits not to mention making the tube last longer in this well-praised set.
Try not to use the TV as there is a possibility of eventual damage the tube or other components.
Please seek a professional repair service.
Although this reply is not a complete solution, I hope it will help you decide the way forward to get your set working impressively again.
Good luck.
rca 38" f38310
RCA told me that today they will start sending out the updated software version to repair the glitch in this tv that cuts out the picture...
tv picture problems.
I was wondering if anyone could tell me what causes faint white diagonal stripes across my tv screen, about an inch apart. I've got a...
White Line Across Television
Hi, I've got a 10 year old TV that, for a while, would display a bright white line for about a half hour before it would finally start...
Another No picture/Sound, but fan running
My F38310 has fan running when plugged in, the on/off green light comes on when turned on, but no picture, menus, text or sound at all....
My antennae cable is connected but the images are
My antennae cable is connected but the images are moving vertically and no sound.
Looking to buy part # R45876221-2 for my Proscan...
Looking to buy part # R45876221-2 for my Proscan PS36800HR any ideas whare to get this part? z5678998@hotmail.com
lcd40883f1080p
need universal remote code
Sansui tv speakers make ticking sound and no audio
Sansui tv speakers make ticking sound and no audio from the programme plays.
Fix-O-Meter
83
83 people viewed this problem
- 0 people are following this problem. Be the first!
Top Standard Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
