Question about Philips HD-5661
Philips HD-5661 How does Foam maker work?
I received this as a gift without a manual, turned the dial to steam but it doesn't do anything to the milk. Thanks for the answer, love that foam
I recently acquired the same model of espresso maker. I have found that you have to turn it on, and give the water time to heat up before attempting to use the steam function. If you turn on the steam knob too early, it will shoot out a stream of water, so you have to wait till the water is hot enough... probably 3 minutes or so. I'm assuming that you already know that you just place the steam spout into a mug of milk to both heat it up and create foam simultaneously. -Tim
Posted on Jan 02, 2008
SOURCE:
Philips Senseo HD7810 /40 stops midway brewing
This lookes like a problem I experienced with another model of the Senseo. The problem here was the 470nF X-capacitor in the capacitive power supply. (230VAC models) Try replacing.
Aug 15, 2013 | Philips Senseo HD-7810 Coffee Maker
Saeco via venezia
It sounds like a heating element has gone out, you have seriously hard water that has damaged the system or you have a burned circuit. Without doing something I would not recommend with that type of system your only real choice would be to send it back for repair. If it is brand new it should have a 1 year warranty.
Dec 03, 2011 | Philips Coffee Makers & Espresso Machines
How do i use the foam setting?
It depends on what type of espresso maker you have. Some have two boilers, many only have one. For the ones with a single boiler, there will be a dial or button to raise the temperature of the boiler enough to steam the milk into foam. Just be sure to drain the line of any excess water first. Once the water stops and steam starts coming out, then you can use the steamer to create foamy milk.
Jun 16, 2011 | Coffee Makers & Espresso Machines
No steam no hot water
Do you have enough water in the tank? Is the filter secured in the tank?
Move the steam dial from standby to steam and wait about 20-30 seconds, should steam if it doesn't most likely faulty.
Jun 14, 2011 | Breville Fresca BES860 2Cup Coffee Maker
I have recently acquired an unused HD5179 Espresso & Cappuccino Bar machine. When I turn it on and hold down the button to aerate, it works away for a few seconds then blows the house fuses. I have not...
I too have the same problem wth HD5179..i took it to philips service centre...they barely looked at it and said SORRY NO SPARES for this model.It seems in INDIA philips does not have facilities to service home use exopresso machines...a sad state of affarirs
May 03, 2010 | Philips HD-5661
Jura capressa F7 steam milk problem
You should decalcify, when you steam the milk some what gets through to the steam and the build up of these minerals causes the issue
Aug 11, 2009 | Jura Capresso C1000 Espresso & Coffee...
Replacement seals for Senseo Coffee machine
If no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee problem
The pod holder has an O ring to seal the black plastic disc in,if it is not sealed you will end up with more volume and a weaker coffee without the foam,either knock the disc out and try and seat the O ring and then knock it back in or buy a new pod holder,I had this same problem
Nov 30, 2007 | Philips Senseo HD-7810 Coffee Maker
Espresso machine
Sometimes the rubber seals on these can be very "stuck" after not being opened for a while - about the best way to free them is to pour a little hot (near boiling) water around the outside of the lid to soften up the seal, make sure you are trying to turn it the right way (anti-clockwise) and give it a little force. You can help prevent this in future by lightly greasing the seal with a tiny bit of vegetable oil - sunflower oil works fine but most should do the job. if the rubber seal looks very distorted or cracked then take it to a hardware store and see if they can find something the right size or try philips support from the same link below. get the user manual here (sorry not available in english, but is available in most other main languages) http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=AEN&cat=KAP_COFFEEMAKERSANDKETTLES_CA&sct=CK_ESPRESSOMACHINES_SU&session=20070307124515_83.54.34.75&grp=KITCHEN_APPLIANCES_GR&ctn=HD5661/90&mid=Link_UserManuals&hlt=Link_UserManuals Hope this helps :)
Mar 04, 2007 | Philips HD-5661
Philips HD-5661 Logo
755 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Deanna Melroy
Deanna Melroy
Level 1 Expert
Kolbrun...
Pierre Laplante
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
