Kenmore 70 series top loader washer machine smells like its burni
I got a new coupler placed on my KENMORE 70 SERIES WASHER MACHINE MODEL 110 92588210 and now it smells like its burning. Is this normal since the motor was bothered. Please help me.
  • 1 more comment
  • jlfunny Apr 22, 2009
    Should I have the coupler redone to make sure it was put on correctly or just run the machine a few times to see if the smell will go away? Please help.
    jlfunny
  • steve
    steve May 11, 2010
    JLFUNNY, Are you referring to the direct drive coupling on the motor or the brake/clutch band on the transmission?
  • steve
    steve May 11, 2010
    If the coupler was not installed correctly it is binding the motor.
  • 121 Answers
You had the clutch coupling replaced sometimes i have noticed that the smell will last a few loads but no more than that
Posted on Apr 22, 2009
Model 22748 kenmore 70 series washer. fills but
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92274800&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
It is also likely the source of the burning smell.
(Sears price $18.86 but available from most appliance repair shops)
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Apr 22, 2010 | Kenmore Washing Machines
Kenmore 70 series washing machine that has a terrible smokey smell. Now my clothes have that horrible smell. What could the problem be and is it worth fixing.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load direct drive whirlpool / kenmore washers use a Motor Coupler between the motor and transmission.
The coupler consists of two plastic pieces with a rubber piece between them.
If the plastic pieces are broken, you may be smelling the rubber piece "burning"
Following is a description of how to access the coupler and check it.
It's a relatively inexpensive piece and is designed as a fail safe between the motor and transmission.
It's very easy to replace if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Nov 25, 2009 | Kenmore Washing Machines
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Mar 24, 2009 | Kenmore 22422 Top Load Washer
During washing the kenmore 70 series washer squeals
Re-check the motor coupler.
If it was not seated flush on both post it will bind and squeal.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
My 70 series Kenmore washer will not spin
REPLACE MOTOR COUPLER/ IT FIXED MY WASHER SAME PROBLEM, DIFFERENT MODEL. HOPE IT HELPS YOU.
Feb 03, 2009 | Kenmore 23822 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Kenmore 70 series model 100.xxxxxxx
Forget about the belt and replace the coupler first. if that doesnt fully fix it then replace the clutch. But just changing the drive coupler should fix it up good as new.
Nov 15, 2008 | Kenmore 24032\24036 Top Load Washer
Does it hum or click? If it clicks your coupler is out or a hum could be a faulted gearcase.
Aug 19, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
577 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
