Question about Fujitsu Siemens LifeBook C1110 Notebook
Wifi hi when I switch on the wifi a blue screen with white writing appears telling me that the system must shut down .Could this be caused by downloading the wrong drivers .What is wrong it didn't happen before and also what drivers shold I need to install as I have just had to format the hardrive thank you paul
Blue screen
If you have windows operating system and the blus screen has writing on the screen read the writing, it is telling you what the hardware error is.
Nov 11, 2013 | Computers & Internet
Tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 | Computers & Internet
Win xp star up and blue screen apears then automaticaly restarted and do the same thing again?
A blue screen can be triggered by several issues with the operating system, or a hardware driver problem, or other issues.
When it reboots start tapping the F8 key in the top row of keys and keep tapping it until you get to a black screen with white writing on it. Look for the option to "Disable automatic restart on system failure" by using your up or down arrow key.
Once highlighted hit your Enter key and when it stops it should give you blue screen with white writing on it. This will have an explanation of why it stopped and gave you the error.
That information will be helpful to further assist you. Write it all down and then post it back using the option to "add a comment".
Apr 09, 2011 | Computers & Internet
Acer4310 suddenly appears white screen
Fyi, White screen for Aspire 4310 and 4520 after 2 years is normal. All you can do to fix it is CHANGE THE LCD.
Try to find any computer shop or go direct to Acer service center to change it
Mar 22, 2010 | Acer Aspire 4315-2963 Notebook
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
My acer aspire screen says technical info ***stop oxoooocif5 (oxoooooooo,oxoooooooo,oxoooooooo,oxoooooooo) can not get any joy for getting into windows,anyone got any ideas to fix this.
And blue screen come on with white letters. It can caused by viruses, from unexpected shut downs and a lot of such kind of things, most of those cases operation system is demaged and may fix by reinstalling it, it you are familiar to bootable medias an a lot of tools you can scan your PC with sacndisc/chkdisk and problem may automatically disappear. Use F8 at startup and choose SAFE MODE to ensure that OP system is not "almost dead". Download any linux LIVE immage and boot from it, if PC is working LINUX wil turn on and no warnings will appear.
Jan 04, 2010 | Computers & Internet
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Computer shut down
That is called the "blue screen of death". Another words your system crashed. Did you download any software, music, drivers or screen savers? If anything, what exactly did you download. If you just opened a web site, sounds like your may have gotten a virus. Try restarting and try to boot into "safe mode". Run your anti-virus making sure you turn off system restore first and delete all internet temp. files/ cookies/ and history. Delete your recycle bin/ restart and see if that takes care of the problem.
If you still can't boot without the BOD, try doing a system restore to the point before this started. Make sure to turn sys. restore back on once you solve the problem. If the blue screen comes up again, as soon as you see it hit pause on your keyboard and write down what it says; especially the error code; 0x0000008 etc.
Oct 16, 2008 | Acer Aspire 3000 Notebook
Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
Aug 03, 2008 | Archos 605 WiFi Digital Media Player
Fujitsu Siemens LifeBook C1110 Notebook Logo
308 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
