Question about JBL CREATURE II Computer Speakers
Speakers stop playing when bass is turned up
When the volume and bass levels are high, the sound shuts down in spurts, then comes back. When I lower bass level, the problem stops. Is this a built-in protection thing or is there a problem? Thank you
How do i lower the bass on my speakers. what controls to i use
Posted on Feb 09, 2009
    President:
  • 2,022 Answers
May be there is problem with your woffer spk bcoz bass is contrlled by woofer see if you can see the spk cone is not tear or it is damage. bye
Posted on Sep 24, 2007
After playing a a few small gigs my husbands Hartke vx3500 bass amp cuts out with the sound BUT the head seems to stay lit up, dont have problems when a low volume but during a gig has randomly cut out for...
It has something loose on the board or where the speaker wires connect. Combo amps are really bad about doing this. The vibrations from the speakers loosen the components on the board.
Sep 03, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
I installed a Pioneer DEH-P800PRS head unit and 4 Kenwood KFC-1662S speakers in my 2003 Dodge Dakota extended cab truck. I used a Kenwood KAC-5204 2 channel amp connected in parallel. Sounds good at lower...
Hello.... sorry to hear about your problem. Bass is the ultimate evil of coaxial speakers. You have a couple of options here, and this is just my professional opinion because I do not know what your lifestyle details, such as truck space needs, type of music you listen to, budget, etc. If you are looking for alot of bass, the best bet would be to use 2 external amplifiers, 1 for the interior speakers, and 1 for a subwoofer. You would then need to purchase an electronic crossover. With this setup, you can remove all of the low frequencies from the coaxial speakers and put them where they belong, with the sub. You will gain EXCEPTIONAL clarity and a very high volume before distortion level. Again it will depend on what your budget is and if you are willing to compromise on some cab space. The only other option you have at this point is if you are wanting to play your music at high volume levels, you will just need to reduce the bass level as you increase volume. I hope this has helped. Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Pioneer Car Audio & Video
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Noise from speakers when playing basses
Offhand, could either be the subwoofer speaker itself or the electronics (amp and/or crossover). One way to determine is by physcially checking the sub speaker. When playing with bass on, pls try restricting speaker movement by pressing on it and see if the noise is reduced. Another is to temporarily replace the speaker. You can try speakers meant for the car, home entertainment or book shelf, just dont set the volume too high.
If the speakers are ruled out, then it would be the electronics inside. For this, you would need familiairty with electronic components and circuittry, a DVM and a soldering iron. Access to an oscilloscope and an audio signal generator would be nice but not a necessity. The idea is to inject a constant audio signal and determine where the noise (if electronic) is coming from. In most instances, it would be a leaky electrolytic capacitor either in the input stage or feedback loop. At other times, it would be also a capacitor in the band pass filter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Audio Players & Recorders
Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Apr 20, 2008 | KLH 1230SB Main / Stereo Speaker
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Head Unit Shuts Off At a Certain Volume
check your ground, it could be that your antenna is the only source of ground, in which case the deck does not have enough power to stay on when it draws too much power. I've seen exactly what you are saying many many times. Ground it really reallly good.
May 10, 2007 | Alpine CDA-9853 CD Player
Tweeters fading out
Turn on the HPF it will definatly clear up the sound.
Aug 07, 2006 | MB Quart DSD 216 Car Component System
JBL CREATURE II Computer Speakers Logo
329 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
