Question about Epson Stylus CX6600 All-In-One InkJet Printer
Changed ink, but it still says the ink is low
Epson stylus cx6600-changed ink, but it still says the ink is low and to replace the cartridge/
  • trurometro51 May 12, 2009
    I have exactly this problem. CX6600 Printer says change Cyan. I changed the CYAN twice using Epson own and Staples cartridge. Printer still says change Cyan!!! I have tried cleaning nozzle. Will try again but...
Epson cartridges have to be reset with a inexpensive reset tool you can find on Ebay. It should have been reset at the factory, but this is not an uncommon problem. If it is new, I would get an exchange. Also if you can find a printer refill store such as Cart~Wiz, you might be able to get someone nice enough to reset it for you.
Posted on Jun 04, 2009
Colour quality in photocopies and printing deteriorating
Well the first thing that will cross ones mind is the ink level.
So check the ink level on the pc will printing a document.
Because this problem mostly caused due to low ink level, try changing the cartridges.
Thanks.
Dec 13, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Cx6600- I have run nozzle check, changed ink and run head cleaner, re run nozzle check but the paper continues to run through the machine without printing. Can you help? Thank you.
try to reseat the ink cartridges, meaning take it out of the printer then out it back,
press set up, press the top left button until you see replace ink, press the color button. take out the inks and return it. close the cartridge cover
Feb 11, 2010 | Epson Stylus CX6600 All-In-One InkJet...
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My Epson CX6600 prints but the words seem to have skipped parts. No word or line is complete. Although there is ink, printing is very light. Any suggestions?
This sounds like you need to replace the ink cartridges. Stuff is missing because the ink is very low or empty. Also, if you have just replaced the ink cartridges then you might need to do a cleaning cycle on the printer.
Jun 09, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Mostly yellow print out
i think your color cartridge are not jetting fully..other nozzles are not jetting ..the main reason for this is low ink level and clog nozzles..
you need to replace your cartridge if you satisfies with your ink ...try to wipe the cartridge in a wet cloth ...
May 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer continues to tell me low on ink.
i replaced cartridges , error , said to replace cartridges. I then removed the new catridges, and now, can't drop the cartridge back in the scanner.HELP
Mar 01, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Changing Cartridges
I inspected the users manual, there it writes:
The steps below to replace an ink cartridge: Caution: Leave the empty cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. To ensure good results, use genuine Epson ink cartridges and do not refill them. Other products may cause damage to your CX6600 not covered by Epson’s warranty. 1. If an ink cartridge is empty: Look at the LCD screen to see which cartridge is empty, then press the x Color button. If an ink cartridge is low: Press the Setup button to enter Setup Mode, then press the green button next to the LCD screen until Replace Ink is displayed. Then press the x Color button. 2. Lift up the scanner 1314127a0e502194c0d970046a123efc.png 3.Wait for the ink cartridge holder to move over, then open its cover.
4. Identify the cartridge you need to replace. Press in the tab at the back of the cartridge, then lift it straight out. Dispose of it carefully.
5. Before unwrapping the new cartridge, shake it gently four or five times. Then remove it from its wrapper.
6. Insert the new cartridge into the holder. Press down firmly until it clicks into place.
7.
Close the ink cartridge cover.
8.
Lower the scanner.
The CX6600 begins charging the ink delivery system and “Charging . . .” appears on the LCD screen. Wait for charging to finish before using your CX6600.
Caution: Never turn off the printer while “Charging . . .” appears on the LCD screen, unless the CX6600 hasn’t moved or made noise for more than 5 minutes.
Jan 23, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Change the ink cartridge in the CX6600
you should be able to navigate on the little screen directly on the printer. try pressing the left or right arrow keys until you see change cartridge.
Oct 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Brand New Printer
Hi Teetle, No, it not normal to only get two pages per cartridge. I would try the following before contacting Epson tech support: -Remove the cartridges and clean the contacts on both the printer and cartridge. -Reinsert each cartridge making sure it is seated correctly. -Buy one black cartridge and install. It is possible that the cartridge is defective but since the magenta cartridge is showing low its unlikely. Tech support will want you to try it before they will replace the printer so you?re best off trying it now. If after trying this steps there is no change and if you?ve had it for less than 7 days I would talk to your retail store. Usually they will just trade your defective unit for one in stock. If you have had it longer contact Epson support and explain what it happening and what you?ve done. Make sure you mention you?ve bought a new Epson black cartridge with no change. Let us know if you have any other questions and please don?t forget to rate this post.
Jan 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
426 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
