Question about Garden
Wont go forward or reverse
Engine runs fine
  • throbinrobin May 06, 2009
    My Craftsman LT2000 won't go forward or backwards either. I need a BELT DIAGRAM for the upper belt. Not the diagram for the mower deck. That way I can make sure that the belt is on correctly.
  • 490 Answers
Is the clutch engaging?? or is it chain or belt driven??
Posted on Apr 22, 2009
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
What could the problem be with 1999 villager wont go forward or reverse?
I forget the name, but it could be the shift connecttion. It the connection point behind the shifter in the car and the transmission. The port disconnected mine in my car cause they couldn't figure out how to shift it. It basically put the car into nuetral. No forward no reverse. But engine runs fine.
May 20, 2014 | 1999 Mercury Villager
My alero with a 2.4 cylinder wont go forward but go in reverse
You have a failed transmission, have it taken to a transmission shop for repair.
Jun 15, 2012 | Oldsmobile Alero Cars & Trucks
1983 mercedes 300D. Transmission problem. Reverse works fine, but engine just revs, like in neutral, in drive S or L. Fluid and vacuum are ok. My brother-in-law says just back to work (ha ha) He listens...
hi not sure on this particular moddel but usualy the sollenoids that run reverse and the forward gears are different so if the forward sollenoid is out it wont select certain forward gears. this will prob mean that the pan on the box needs to be removed and the filter and then both sollenoids (or there may be 3) but you should replace them all...
Feb 11, 2010 | 1999 Mercedes-Benz E-Class
Car does not drive forward but works in reverse
Sad to say but your automatic transmission has bit the dust.
Jul 24, 2009 | 2004 Chevrolet Cavalier
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Transmission wont respond in any drive gear
I bet you didn't get it full of fluid. CHeck the dipstick with eng. running and trans. in Park. Add fluid till it moves, but while adding, have someone shift it back and forth through all the gears with engine running. If not, you have a burnt-up transmission.
Apr 21, 2009 | 1994 Chevrolet S-10 Blazer
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
