Question about LG WD-12126RD Front Load Washer / Dryer
FAULT CODE MY WASHING MACHINE KEEP COMING UP WITH FAULT CODE "DHE" ONLY WHEN WE HAVE IT ON TO DRY
  • Sue J Nov 17, 2007
    Same problem , ours doesnt go into dry mode and our model is 12124 rather than 12126. Engineer states everything is ok (wiring, heater, thermostat, fuses)and cannot come up with a solution
AI got here after googling the same problem.
There are many reports of this "dHE" error - all with BRAND NEW MACHINES !
I rang LG in Sydney, Australia today and amazingly the girl on the phone said there are no known issues with this dryer
(In Australia the combo dryer is known as WD14700RD ) - 7kg washer / 4kg dryer.
Mine has same problem. Whenever the dryer is selected in the program, it stops after the wash phase and flashed dHE (or dHe, can't remember) and thats as far as it gets.
Its a tech, call out tomorrow to try & fix it.
Very poor LG, these are brand new machines, many reports of this problem from googling it but LG have no knowledge a problem.
This may end up being a recall or at the very least, some public announcement of this dHe problem with this washer.
New buyers beware ... It is a fault with brand new machines.
Steve
Melbourne Aust.
Posted on Jan 16, 2008
  • Steve R Jan 19, 2008
    Follow up - After service call out.
    Service man found several possible causes.
    He unscrewed the top of the machine off & said dHE errors are related to the dryer components. He started a dryer cycle & watched & lisened to machine.
    He observed the dryer fan was not starting up.
    He unplugged the power cable to the dryer & replugged.
    The fan now started up, but only with cold air.
    He then looked towards the front of the machine & noticed several cables had come loose from their sockets, one he identified was the heater element cable.
    He plugged that back in & another unknown cable was also loose. He plugged that back in.
    It worked.
    dHE error gone & dryer fan started & pumped out hot air.
    It seems at least a few of these machines during transit (from South Korea?) fail due to cables coming loose from their sockets.
    dHE errors result if fan cable & fan heating element cable come loose.
    My thanks to WAM electrical repairs in Box Hill (Melbourne) for helpfull advice & successfull repair.
    For people looking at buying this machine, it washes & now dries perfectly well & I am happy with the machine.
    But beware that this problem is out there (there are several other reports I read) which is easily fixed but does require a service call out, under warranty of course.
    Steve, East Melb.
    [email protected]
SOURCE:
I got C4 error on Hitachi FX80GJ washing machine and it stopped spinning. How can I fix it ?
Hitachi washing machine top loading is Sher coming C4 is dry too much sound coming
May 16, 2015 | Washing Machines
Tip
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG washing machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Mar 15, 2010 | Washing Machines
I have a lg wm3431 and it does not dry i get and error code of dhe every 10 minutes is it expensive to fix?
The dryer heater is not working. You will need a technician to diagnose this problem. It is possible that the condensate tube and 2 thermistors are clogged with lint debris and will need to be cleaned out.
Good luck
Jun 15, 2011 | LG WM3431 Front Load Washer / Dryer
Error codes
Here are the common error codes for the LG machines.
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
UE
IE
LE
PF
FE
PE
CE
TE
SE
HE
DHE
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Lg washer dryer
The DHE error is dryer heat error. It's a problem with the heating element or thermister. You can find the service manual herehttp://www.appliancefactoryparts.com/content/pdfs/129017-8.pdf
Nov 11, 2007 | Washing Machines
Error code dHE
Several reports in Australia of brand new LG Washer/Dryer combo (model number WD14700RD) getting dHE error's with very 1st dry cycle.
I bought a LG WD14700RD last week, and yup, washed fine.
Dryer cycle results in dHE error.
Everytime.
Cycle stops & you just have to power off the machine.
It worked.
But beware that this problem is out there (there are several other reports I read) and it have this problem, which is easily fixed but does require a service call out, under warranty of course.
Steve, East Melb.
[email protected]
Oct 06, 2007 | LG WM3431 Front Load Washer / Dryer
LG WD-12126RD Front Load Washer / Dryer Logo
735 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
