Question about ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2 Phenom FX/Phenom/Athlon /Sempron Socket AM2/AM2+ 5200 MHz... Motherboard
I connect the switches to system panel connector and my computer doesn't boot up?
I'm trying to boot my computer I can't connect the system panel connector to the motherboard?
  • 75 Answers
Http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M3N78-VM
here u can download manual ..then follow the manual
Posted on May 11, 2009
Reboot and select proper boot device problem
The simple soltion to this problem would normally be to open the side panel of your computer chassis and check that all connections to and from the hard drive are making good contact. Push the connectors in gently including the power connector and the data connectors on the mainboard. Now boot up your computer system.
If the problem persists then you may need to do the following:
Enter the BIOS by tapping the Delete key during first powering on the computer. Now ensure that the main hard drive, known as the Master boot device is set to 1st in the boot priority menu.
Hopefully it's just a loose connection. A more serious explaination for this occurrence is that the hard drive has failed. In other words it has died/faulty and is therefore not working with your computer.
Take care!
damnor01
Aug 11, 2011 | Microsoft Computers & Internet
Motherboard booting problems...How do I solve?
Hi
Try to boot with 1 stick of ram then swap it with the other and try again. Next unplug the case front connections from the mobo header (pins). Draw a sketch where they all go so you don't forget. I'm talking about the power switch, reset SW, HDD LED etc. Also remove anything connected to the back panel printers etc. Also remove the mouse and keyboard. Carefully, momentarily short the pins that were connected to the power switch and note results.
If it still doesn't boot, remove all parts from the mobo except 1 Stick of RAM, graphics card, PSU, and of course CPU. Leave the mouse and keyboard unplugged. Try to boot by shorting the mobo pins again. If it doesn't boot it is most likely either the PSU or the mobo. It could also be the CPU or RAM but it is less likely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | EliteGroup RS482-M754 Motherboard
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I have a Dell Inspiron 546 running Windows Vista. When turning it on the Start button lights up, but the display very quickly goes into power saving mode. Nothing further can be done. The computer or...
Hi. Were you able to see the the DELL post screen when you turn on the computer? Take out the battery and unplugged the power adapter from your computer and to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn on the computer.
Nov 07, 2010 | Dell Inspiron 546 MT Desktop Computer
I'm having a Booting issue... I push the power button the lights flash a few times then go out... No boot
Plug the laptop into the wall, if you don't no boot, then it is your hard drive. If you do get it to boot it is your battery gone bad.
Nov 21, 2009 | Dell Latitude C800 Notebook
HOW I IDENTIFY THE POWER SWITCH CONNECTION IN FRONT PANEL OF MOTHERBOARD INTEL DESKTOP D850MV?
Hi u can easily Connection With your pc
1. Open Your computer cover and see the system panel connectors
2. a use of screw driver attach with one by one in system panel connector and you can easily know your system panel connector settings
Thanks
Mukesh
mukesh_ibm@yahoo.com
May 12, 2009 | Computers & Internet
Is It required to connect Tower Front Panel I/O to Motherboard
The only front panel pins you need are for the power switch. Track them from the front panel to the connector and plug them upto the 2 pins for power. Dont worry about polarity it can go either way. The connector may look a little odd but it will work just fine. In the past in that situation I have cut the plastic in such a way I have separated the different connections but its not worth the trouble in my opinion.
May 06, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Computer will not boot
Option 1 :
Remove completely the mother board from Cabitnet.
Try to check it on other Cabinet.
Option 2
Remove mother board and re- plug the SMPS power Connecter to Mother board outside of cabit and make sure that motherboard is not touching directly to Metal part of cabinnet.
then switch on computer and check
Nov 22, 2008 | ASUS P4S800-MX Motherboard
Front panel leads Emachine model T2862
E-machine model T2862 pin-out for the 10-pin front panel header is screen-printed on my Emachine's motherboard, but is so small and far away from the actual pin location, that it is likely being overlooked. If looking into the computer case from the side where you remove the panel, the header looks like a row of four pins with one missing at the farthest right pin location, and a row of 5 pins underneath that, with the fifth pin directly below the missing (key) pin in the row above it. Starting on the first row, you would install the 2-pin connector from the front panel labeled "Power LED" to the leftmost and 2nd from the left pins. (You may need to switch it around to get it to work as the LED is polarized. You will know as soon as the system starts to boot up if it is on properly, as this light burns constantly if the unit is on.) Then, to the right of that connection, you would connect the 2-pin connector labeled "Power Switch" to the 3rd and 4th pins from the left on the first row. (It does not matter which way around this connector plugs on, as all we are really doing is allowing the front panel button to connect these pins together to turn the system's power supply on when you press the button.) OK! Drop down to the BOTTOM row of pins below the first row. To the leftmost and 2nd from the left pins on the second row you will install the connector labeled "HDD LED". (Again, you may have to switch it around to get it to work since it is polarized. You will have to watch the system boot up and as the hard drive is accessed, you will see it blinking randomly if it is connected properly. NOTE: You will not damage anything if this or the power LED is hooked up wrong. They simply will not function. So don't fret, just switch them around.) Next, the header has room to connect a reset switch if your system has one. (Mine does not.) You would install the 2-pin connector labeled "RESET" to the 3rd and 4th pins from the left on the second row of pins. (Again, this is a connector that works fine regardless of which way around you install it, as it simply lets the reset button connect these pins to reset the system when the button is pressed.) Finally, you will notice one pin is left unused below the missing (KEY) pin. As far as I know, this pin does nothing, but is likely a ground or maybe a source for DC power as I have seen before. The unused pin above it is for manufacturers who make one connector coming from the front of the case which is pre-wired with all these functions, so the connector (usually with 10 total possible wire locations) can have that one location sealed or capped to prevent someone from installing it the wrong way around and potentially sending voltages somewhere they shouldn't be going, or causing something to not work properly. I made a quick pic in MS Paint below for better reference:
May 23, 2008 | Computers & Internet
Not running on startup
I occasionally have a similar problem with a couple of my KVM?s and I think it relates to the circuitry in the KVM that is supposed to fool the PC into thinking a mouse/keyboard is attached. Windows doesn?t see the mouse so it doesn?t load the drivers unless you force it. What works for me is to just start the PC and switch the KVM to that PCs port and leave it there till the computer finishes booting. Then its safe to switch to the other port, probably not the elegant solution you were looking for but it works every time.
Jun 18, 2007 | Belkin OmniView SOHO 2-port KVM Switch
ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2 Phenom FX/Phenom/Athlon /Sempron Socket AM2/AM2+ 5200 MHz... Motherboard Logo
328 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
