Question about IBM ThinkPad T21 Notebook
IBM Thinkpad Bios Password
My IBM T23 Lost date and time and so on booting it will be bring the date and time error which prompts me in the bios. Unfortunatel the bios has a password which I dont know, I have tried the IBMpass software to read the eepron but have failed. I have also changed the chip storing the IBM passwords but have still failed. Any other means please?
Thanks.
Moses Lukato
Got used thinkpad 2647 and cant get it to go to BIOS
Press the F2 function key when you boot up the Thinkpad to get into the BIOS configuration.
Feb 11, 2012 | IBM Computers & Internet
MY IBM LAPTOP T23 2647ASKS FOR BIOS PASSWORD WHICH I DO NOT HAVE WHEN EVER I SWITCH IT ON.NOW I CAN NOT USE IT.
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Nov 26, 2010 | IBM ThinkPad T23 2647 Notebook
Hello how to reset bios password of ibm thinkpad t23 2647
To unlock the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Take care.
Nov 19, 2010 | IBM ThinkPad T23 2647 Notebook
IBM Thinkpad has black screen with a lock icon
When i got black screen on my Windows 7 laptop when started pc, Windows Boot Genius helped me fix problem without data loss easily!
Jun 08, 2009 | IBM ThinkPad T23 Notebook
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
T23 BIOS error code #05
are you getting a date & time error ?. you could always try just resetting the bios.... remove the bios battery AND the battery itself for about five minutes or so. install it all again and boot up.
Robert
Aug 27, 2008 | IBM ThinkPad T23 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Utility to reset the time and date.
Jul 17, 2008 | IBM ThinkPad T21 Notebook
Thinkpad 380ed
1) This is a typical problem when the CMOS battery is very weak or dead, it will continually display the date and time and reboot with the same errors until you change the CMOS battery. On this model it is behind the door that houses the memory chip, above the battery, if you have the laptop turned over and battery closest to you. <--best bet, its a dead CMOS battery.
2) You can get to the BIOS to run tests, one of 2 ways, either hit the ESC key and other keys to get a 301 error or hold the F1 key and boot, you should get into BIOS. (You probably won't be able to do this until you replace the CMOS battery.) From there you can run diagnostic tests on various components.
3) Lastly, you can update the BIOS. From inside the EASY-SETUP bios you should be able to copy the BIOS part number, date, etc. Look for the BIOS update based upon model # either thru a search on the web or directly on the IBM website (a search on google of "bios update thinkpad 380ed" will bring up a link for the IBM page.) If you choose to do a BIOS update, read the directions carefully and remember not to power off the machine while the update is happening. If you've never updated a BIOS before, get someone who has to walk you thru it before attempting it by yourself.
GOOD LUCK :)
Sep 19, 2007 | IBM ThinkPad 380ED
IBM ThinkPad T21 Notebook Logo
342 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
