Question about Hannspree 28" Widescreen Flat-Panel LCD HD Monitor
Monitor dims on a black background hanns G 28
I have a Hanns-g 28 inch monitor on my desktop. While playing a game if it is dark the screen dims even more. If I am running a .txt program with a black background or even my nvidia monitor wizard had a black screen all dimmed
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Posted on Dec 31, 2010
How to open Hanns G 28" monitor.
3 screws across top and 2 in lower images?q=tbn:and9gcszcucatuwbsigg82atflilcifasvtk3ai5_wt5czzf6sn7tgq_0q3 screws across to and 2 in lower corners
if this helps please take time to rate
Feb 01, 2013 | Hanns.G Corporation HW Computers &...
Have a green rectangle about 2 inches by 5 inches in center of screen with yellow letters that say, input signal mout of range. It is A hanns g hg281d monitor
Restart your computer,
and keep hitting the F8 key until a "start-up" menu
(white text over a black background) is displayed.
Choose "Safe Mode" and let Windows start.
Reset the screen-resolution to 800-by-600, and 60 Hertz refresh-rate.
Restart your computer, normally,
and then "tweak" the screen-resolution and refresh-rates that are "optimal" for your monitor.
Aug 09, 2010 | Computers & Internet
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNS·G JC199DP LCD Monitor 19...
My Hanns.g monitor 1080P HDM1 has a power problem, when it's turned on either by the power switch or when it's activated by the keyboard, it flashes on & off several times & then goes off, playing...
nfleurat, If nothing wrong with the "on"/"off" switch, then must be the "switch-mode-power-supply"/"CCFL inverter supply" circuit card inside of unit. Look for a possible "thermally intermittant solder connection" and then resolder it. Also, inspect unit for possible "swollen" electrolytic filter capacitors on power supply board. Read more of my responses to other owners in my FIXYA profiles for more options you can use to solve your LCD display problem. 12fixlouie aka louie12fix Good luck on the repair.
Jan 05, 2010 | Hanns.G Corporation Computers & Internet
My screen on my Hanns-G28 inch has tinny little
sounds as if the lcd ink is leaking. you probply need to replace the screen.
Dec 27, 2009 | Computers & Internet
Blank part on my monitor
This sounds like a claim. Give it back to your seller.
May 28, 2009 | Hannspree HANNS·G HC174DP 17 inch LCD...
My hanspree hf289h monitor has recently started to flash its menu on the screen times between the flashing menu and the time it stays on the screen vary. I tis about 3 yrs old
The older Hanns G monitors had there flukes, contact Hanns G about the issue, there is no physical fix. They will be able to help you. The new Hanns G screens are amazing, i had 3 of the 28" screens off newegg! :)
May 07, 2009 | Computers & Internet
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Hannspree 28" Widescreen Flat-Panel LCD HD Monitor Logo
2,197 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
