Question about Kenmore Dryers
I have a kenmore elite dryer model 110 62062100 that has been getting hot (cabinet get very warm on top) and does noy dry all the way. it shuts itself off before its dry. any idea what part is needed? Thanks Scott
  • 2 more comments
  • rebeldowg Apr 23, 2009
    Mike,
    all vent and traps clean, but still does it. could it be the thermistor?
    thanks scott
  • rebeldowg Apr 24, 2009
    mike,
    It does have a thermistor on it and i do have a meter. it asked if i found you helpful and i did, when am i suppose to rate you?
    thanks scott
    thanks mike
    i will try that this weekend,
    scott
  • rebeldowg May 05, 2009
    Mike,
    Pulled the thermistor out and it had a thick coating of lint, check with meter and it read good. cleaned the lint and reinstalled thermistor and it works great. must have been the lint insulating sensor.
    Thanks Scott
    Genius:
  • 1,122 Answers
Most of the time when this happens it is from a clogged wall vent or clogged dryer vent or clogged lint trap,check and clean all 3 and let me know how it does-mike
Posted on Apr 23, 2009
  • 2 more comments
  • MIKE major Apr 23, 2009
    it could be the thermistor ,remove the back panel and see if you have one located on the blower box,do you have a meter?mike
    why did you rate me ready????????
    why didd you rate me already????????????
  • MIKE major Apr 24, 2009
    put your meter on omns and check it if you get a reading it's good,if you get no reading at all it's bad-mike
My Kenmore elite smart heat quiet pak 4 automatic dryer model 110. 87872603 shut off during drying cycle and showed service code f23. The dryer was extremely hot.
call sears service . sounds like the exhaust blower has failed you or perhaps the filter us plugged and needs cleaned out which should be done before or after each use
Jun 16, 2015 | Kenmore Dryers
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
Kenmore Elite Oasis dryer 110.6708 that gets too hot
did u clean machine filters? in the back of your machine there is a big silver pipe itmay need to be clean too
Jan 21, 2010 | Kenmore 67082 Electric Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer HE4 sounding like a boot is in it.
Check the drum rollers inside the cabinet, go to appliance guru and it will show you how to get to them.
Jan 16, 2009 | Kenmore Elite HE4 Electric Dryer
Removing cabinet of kenmore elite washing machine
It would help if I had your model number, but I'm assuming you have a Kenmore top loader that has the fill hoses attached under the left rear of the washer casing. With the brass clips removed, you should be able to move the cabinet off the frame slightly to give you enough room to reach your hand under the wash tub rim and disconnect the hoses. You may need a set of pliers to remove the hose clamps. I hope this helps you.
If you are having difficulty, please post back and let me know.
Was there a reason why you were removing the cabinet? Do you need further assistance?
May 23, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
362 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
