Question about Toshiba Satellite L305-S5894 Notebook
My wireless internet doesn't work, and the on/off switch is turned on
My wireless stopped working yesterday. I looked at my devices, and it says that the adapter doesn't work.
  • 31 Answers
Hi,  Please do the following: Start>Run>type devmgmt.msc>under device manager>Right click on Wireless network adapter>uninstall, once done, click on scan for hardware changes on top. the network adapter would be back on its place. If that doesn't resolve the problem, reinstall the driver for wireless network adapter using the link given below: http://www.drivershq.com/Drivers/Toshiba/Satellite/L305-S5894/4183/9941/42341/Drivers.aspx
hope this resolves your issue.
your feedback is appreciated. Askari :)
Posted on Apr 22, 2009
My son watch youtube videos on innotab max yesterday it just stop working it seems unable to load the videos it just has 2 round arrows going round
It must be due to slow internet connection. If you have connected the tab with a wireless router, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanMySpeed.com before and after following these steps.
Jan 28, 2015 | YouTube Computers & Internet
Wireless not seeing internet but ethernet is
Try uninstalling the wireless adapter from the control panel. Reboot the system (although with Window 7 that shouldn't be necessary), and let it Windows auto-discover the device again. Disable/enable doesn't for Windows to re-install everything.
Jun 15, 2012 | Acer Extensa 5620 Notebook PC
My wlan (function/F10) key doesn't work/light stays amber!!!!! No wireless internet/Internet only works when directly plugged into PC.
Check in device manager for the wireless card. Right click 'my computer' select 'properties' click the hardware tab and device manager, it should be listed as a network device. if it's listed update the drivers, it may just be disabled in windows. If it's listed as installed and working correctly in device manager it may be faulty.
you can also try running 'cmd' to lauch the command prompt and typing "ipconfig /all" this will show all available devices in your computer and their state.
Good luck.
Apr 22, 2012 | Compaq Presario Notebook
I can't get my wireless to work on my laptop - I honestly cannot even remember when or how it stopped working. I get a message when I try to connect: The network adapter "Intel (R) WiFi Link...
Very first thing to try is check to see if the wireless is turned on!
There may be a small switch on the case that must be turned on. But this doesn't sound like your problem--just thought I'd mention it.
Then go into the device manager and remove the adapter. Don't worry--this won't hurt anything.
Restart the computer and let it find the adapter. It should work after that.
Other than that, I'd have to know the actual settings on the adapter to help you.
Jun 13, 2011 | Acer Aspire 5735-6694 Notebook
My wireless in the computer does not work. diagnoses say there is not cable connection
Try the following, retype your wep or wpa.
then try to connect again
If this doesn't work, go to run and type services.msc
look for wirelesszeroconfiguration. click stop or start which ever toption is available. But make sure it on start.
Try to connect to the internet again.
Jun 10, 2011 | HP Pavilion dv4000 Notebook
How do I switch on my SONY VIAO Laptop to accept wireless internet, which I know is working fine
Depending on the model you own, most Sony Viao laptops have a small slide switch along the front edge.
May 27, 2011 | Computers & Internet
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Harware switch of wireless internet not working
hi..have you tried to download acer empowering technology software from the acer website?i had the same problem but when i downloaded the software the wireless started working fine again..exept the switch on the outside doesn`t respond but the wireless works fine-.
Jul 18, 2008 | Acer Aspire 1640Z Notebook
Wireless Switch
From your description I agree, its probably a damaged switch. I never recommend anyone taking apart a laptop unless they are a mechanical whiz, have experience with laptop disassembly or can afford to break it beyond using. As far as turning the built-in wireless card on without the switch there might be a way. I don?t have a Compaq laptop to experiment with, however, my Dell Latitude BIOS settings has a setting to automatically turn on the wireless card at boot-up. Perhaps yours does too, during your laptops initial boot process get into your BIOS setup menu (press F2 or if that doesn?t work F10 keys). Look for an option relating to your built-in devices or wireless device. My Dell setting is fairly ovious: "Turn on wireless device". If you find a simliar option turn it on, reboot and look for the wireless adaptor. Another option may be to buy an inexpensive UPS wireless adaptor. You can pick them up on Ebay for around $30, not as spiffy as the built-in but probably a lot cheaper than paying a repair shop to fix a three year old laptop. Good luck.
Dec 02, 2006 | Compaq Presario 2100T Notebook
Toshiba Satellite L305-S5894 Notebook Logo
255 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
