Question about Nview Z215 10.4" LCD Panel with Video(16.7 Million) Z215 Multimedia Projector
NEC VT470 Multimedia projector
This projector does not light up. The power indicator lights up and the Status light keep on blinking. Replaced old light with a new one. It does not light up. Any assitance on this matter is appreciated. Luke
    Master:
    Sergeant:
  • 461 Answers
Try to reset the projector. Turn the power off. remove the power supply cable from the main socket. Leave it for 30 min. Turn on again. Before turn on(Make sure) 1.0 power cable install correctly 2.0 Lamp cover install correctly. 3.0 No excessive heat around the projector All this can be refer to the user manual.
Posted on Sep 24, 2007
SOURCE:
NEC vt470 projector suddenly not turning on
I'm with Greg on this, I've had both of those problems individually on different VT4xx's (having both a number of them and a working knowledge of screwdrivers, figured out what was up by process of elimination). Sometimes bulbs die early - if it's really early you might want to see if there was any warranty period remaining on it - and the power boards in these projectors do sometimes break down. They were built in an at-risk period for having troublesome power capacitors installed into them, for starters...
If you are e.g. at a school which has several of these projectors issued to individual teachers, organise to swap the bulbs over between both your units and see which, if either of them, still work afterwards. If theirs was originally working, and after the swap, both are dead, you've got a dead bulb AND something else wrong with the projector, POSSIBLY but not necessarily that PCB. If yours then works but theirs doesn't, it's the bulb. And if there's no change, then both bulbs are good but your projector is toast.
And if it turns out that it's a projector fault, unless either you or an in-house tech can investigate and do the fix either for free or very cheaply, it's probably not worth getting it repaired. These models are really quite old and under-spec these days, and you can replace the entire thing with a brand new model of similar specification - with a working bulb installed! - than it would cost you to buy a single replacement bulb for the NEC.
Nov 08, 2012 | NEC VT470 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
Nec vt470 lamp does not come on. replace lamp, when turned on status light turns red and get 3 beeps. lamp does not come on.
If you replaced the lamp already, chances are the ballast is defective. When you power on the projector with the power button you should see a flicker of light in the lens, or an electrical sound. If you don't you ballast is bad.
Apr 19, 2010 | NEC VT470 Multimedia Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Status light blinking red
Oct 23, 2007 | NEC VT47 Multimedia Projector
NEC VT47 lamp won't light
According to the manual, yes . . .probably gone past the recommended hours of lamp use. Press the OFF or the HELP button on the remote for 10 sec, this will reset the lamp hours value and allow the unit to come on. If it don't, NEC will tell you that it has to be sent to a repair center.
Aug 29, 2007 | NEC VT470 Multimedia Projector
Status indicator blinks RED, not starting.
There are different rates at which the status light will blink to indicate various errors. See manual (link below) page 49 http://www.support.nec-display.com/dl_service/data/user_manual/ENGLISH/VT37/vt37_manual_e.pdf
Jul 29, 2007 | NEC VT37 Multimedia Projector
Nview Z215 10.4" LCD Panel with Video(16.7 Million) Z215 Multimedia Projector Logo
177 people viewed this question
Top Nview Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Nview Office Equipment and Supply Expert? Answer questions, earn points and help others
