Question about Apple iPod MA446LL/A MP3 Player
Daughter got a hold of it looks like she deleted everything how do i get it back and get reed of the stuff she out on it Thank You Gloria
You cant get it back unless it still on the computer u download from.
Posted on Apr 22, 2009
How to hard reset the tablet due to insufficient space at internal memory, I cannot download
Have you tried transferring your important/wanted files onto a hard drive or your PC then going through and delete all the stuff you don't want or have all ready savd to your PC or hard drive.
if you have to much stuff to go through make sure you have everything saved on the other devices and do a factory reset that will remove EVERYTHING on your tablet. Then if its an iPad you can hold the lock and home button down until it resets, other tablets I'm not to sure how to manually reset them.
Make sure you back every thing up.
Mar 11, 2015 | Tablets & eReaders
Fisher paykel refrigerator fault model E521T
I had the same problem, constant beeping. I removed the fan, tested it with a 12v power supply, worked fine. The beeping and flashing on the control unit was still happening though. I read online that the door reed switches can play up, so i decided to test this. I took a regular household magnet, the type you use to hold the kids drawings up on the fridge and held it against the door reed switch. Beeping stopped, fans kicked in, everything started working!!!! So I concluded that either my reed switch is not being tripped when the door shuts or possibly a reed switch problem? maybe not as sensitive as perhaps it should be..? either way my next port of call will be look at the seals around the door, are they stopping the door from shutting properly? I thought for a temporary measure you could get a strip magnet and put it inside the reed switch housing. It just means your door wont trigger the internal light when opening...
Jan 19, 2013 | Fisher and Paykel Active Smart E522B...
Have been able to delete stuff before, now can't remember what to do ! need to clear card before hold on monday !
I've uploaded the user manual here UManual.
I think page 45 will help. Also look at formatting a memory card.
Feb 12, 2012 | Samsung Digimax S700 Digital Camera
I have a 1hp 7gal that makes just 40lbs keeps running and gets hot. took the head off suspecting the reed valves but every thing looks like new in there. There was a small amount of blue sort of sealant...
if this is piston driven you need new rings if rotary then you need new air inlet valve unless you have oil in air line then it would need bearings and seals
Jun 22, 2009 | Air Tools & Compressors
Kx 125 reed valves
The reed valve assembly should hold solvent withot leaking. Remove for test. Disassemble and clean reeds and reed seat. Perfect seal is very important.
Good luck,
Techjoel
May 17, 2009 | 2003 kawasaki KX 125
Quick release plate for quantaray tripod
Hi, quick release plate can be found easily at amazon. Click here Amazon com quantaray tripod quick release plate and take a look. I hope I have helped you.
Cheers
Tim
Nov 18, 2007 | Quantaray (291660751) Tripod
2 deleted messages
Press the Clear /Mute button, TAD on should be displayed, then press 2 and the message should be played back,
All the best
Oct 27, 2007 | Uniden Cordless Phone
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
