Question about SanDisk Sansa e260 MP3 Player
How to clear virus on sandisk mp3
Dear Experts, My sandisk mp3 1GB player been attacked by virus think so not getting inside of menu, so how to clear that virus, Its asking for format while go for open, if the solution is formatting means how to do that one, can any one guide me please as soon as possible. Thanks in advance, Cheers, Prabhu....
  • Aero_prabhu Sep 23, 2007
    dear expert,
    i tryed that way also, which u been suggested, its not getting format, can u tell me other alternative solution to clear the virus,
    thanks,
    regards
    prabhu.g
  • 150 Answers
Plug into usb goto my computer mp3 player shows up as removable disc (usually drive F:) right click drive f: and click format (a quick format should work( Good Luck
Posted on Sep 23, 2007
SOURCE:
My sansa will turn on but it will just stay on the sandisk logo and keep repeating that and i cant get to the main menu or anything what should i do
the software of your player is corrupt. It must have gotten a virus from either your PC or any other that it was inserted into. This is why the player cannot load even when it try's to.
Your player needs to be flashed, that is, the software needs to be reinstalled.
This can be done by experts that specializes on mp3 software installation.
Take care
Jan 15, 2010 | SanDisk Sansa e250 MP3 Player
Refurbished Sansa 1gb Mp3 player loses recently downloaded songs
Three may be virus in it. Also there may be a problem in the Memory Chip. Try for Low Level Format the device.
Jul 06, 2009 | SanDisk Sansa m240 MP3 Player
I think that my sansa e260 have a virus, which could be the solution?
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
May 02, 2009 | SanDisk Sansa e260 MP3 Player
My new Dell Vostro does not recognise the Sansa e250, my previous Dell Latitude D620 immediately found it and connected (via USB)
hi
i think the reason may be due to virus attack or the corruption of running softwares in your e250 mp3.also you should install the driver of your mp3 in the lap
Apr 25, 2009 | SanDisk Sansa e250 MP3 Player
I cannnot delete a folder from my sandisk
I think there can be a virus in the Mp3 player......
Pls try to scan the mp3 player with a virus programme and then try to use it.........
Good Luck...........
Apr 16, 2009 | SanDisk Sansa e250 MP3 Player
Rec. problem regarding
If I virus attacked your player (none has, I'm pretty certain) you could reset it. More probably your firmware or memory is defective and the only solution is to exchange it.
Oct 08, 2008 | SanDisk Sansa m250 MP3 Player
My Player has gone weird
yeah right.. i think it has a virus..all you have to do is to scan it with an anti virus...or format your mp3..so that you can use it again..
Feb 23, 2008 | SanDisk Sansa e260 MP3 Player
I think my Sansa has a virus
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Jan 08, 2008 | SanDisk Sansa E280 MP3 Player
Sandisk sansa mp3
k, so now the SanDisk sansa m240 1GB mp3 player, when you turn it on, it freezes. I have tried to change the battery and everything and it still wont work. What is happening here? others that have had the same problem. I researched this online and found out that there was a rather large bad batch of these mp3 players shipped in December. they suggest calling sandisk tech support at 1-866-726-3475 for a replacement and getting a RMA number or going back to where you bought it and exchanging it.
Jul 09, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
158 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
