Question about Targus ACP50US Docking Station
I have a Dell Inspiron 6000/XP pro and a Targus ACP50 adapter. Loading the adapter software and restarting results in a severe reduction in display resolution that is not correctible. I am using the latest driver package from Targus.
  • 1 more comment
  • rrichburg May 07, 2009
    The video feature on my product just stopped working. I am running Vista on a Dell XPS. I did some reasearch and can't find a solution. Any suggestions would be great. Thanks.
  • Anonymous May 07, 2009
    SAme problem
  • Anonymous May 25, 2009
    Same Problem on HP Pavillion Notebook DV2550se with Vista Home Premium SP1. Googled a lot, but no solution found !!!
    Brigadier General:
  • 3,614 Answers
Try to configure the screen resolution. go to control panel display settings.
let me know
Posted on Jun 05, 2009
2005 Dell Inspiron 6000, I need to reload the operating software, my hard drive crashed and I have a new hard drive I am going to install. How do I go about loading in the software??
If you have your windows disc, go into your bios. Make sure your disc drive is the FIRST BOOT DEVICE. Then restart your pc and it should load from the cd.
Mar 23, 2011 | Dell Inspiron 6000 Notebook
I'm running XP on my Inspiron 6000. It's had problems booting when several USB devices are attached (mouse, camera, keyboard, etc). Lately it will not display the windows menu after startup...it goes...
Hi. When you get to the point of having the Task Manager open, click on "New Task" and ty this in : explorer.exe
After which, press enter and see if the start menu comes up. Also try this in safe mode if it does not work in normal mode.
If it also fails in safe mode, that means your Windows is badly corrupted and the only way to get back to normal is to reformat the computer. Cheers!
Feb 12, 2011 | Dell Inspiron 6000 Notebook
Hello, Recenlty, when I started up my laptop I got a blue screen with a message to the effect of "windows has been shut down to prevent further damage." I've tried to restart in every configuration and...
Try to remove the battery and connect the power adapter and the cord only. Making sure that the power adapter has a green light. Then try turning on your laptop. If it fails then the power adapter is broken, you are going to need a new one, exact model of the power adapter. In any case, you can always recover your files by removing the hard drive from your laptop and insertng it to an external casing so that it will be an external hard drive. By this, you can connect this to another computer thru usb connection where you can back up your important files.
Oct 11, 2010 | Dell INSPIRON 6000 CENTRINO...
Installed a rangeplus adapter on dell 1000 inspiron xp sp3 home
See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
Nov 15, 2009 | Dell Inspiron 1000 Notebook
Possess dell inspiron 6000 centino wireless, need drivers and xp
You can contact Dell Technical Support and see if they will send you a new XP CD. All the drivers can be downloaded at Support.dell.com for that system. If you can't get Dell to replace the CD, try Ebay. Here is an Example:
http://cgi.ebay.com/Reinstallation-Dell-CD-w-MS-OS-XP-Pro-SP2_W0QQitemZ300352622860QQcmdZViewItemQQptZUS_Software?hash=item45ee69510c&_trksid=p3286.c0.m14#ht_500wt_1182
Sep 30, 2009 | Dell INSPIRON 6000 CENTRINO...
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
No power
Try purchasing an original adapter. I've had several machine of different make through my shop that the Targus adapter just simply won't run. For example, a Dell Inspiron 1100 and HP dv4000 won't run at all, and a Dell Latitude 1501 and Gateway crv503 will run but won't charge the battery. Targus adapters are junk, if you can, get your money back.
Jun 28, 2008 | HP Pavilion dv1000 Notebook
Power issue
Is the new power supply a Dell. Some aftermarket power supplies, especially Targus, will not charge the battery in a Dell. If it is a Dell supply, then it's one of two things. 1- the battery is shot and needs replacing. 2- the power management chip on the motherboard is shot and the motherboard needs replacing. If the battery light is flashing orange then the battery is shot. If the battery light is green, then go into the power settings and see if the machine shows that it is charging. If it doesn't show that it's charging then it's the pm chip.
Jun 16, 2008 | Dell Inspiron 6000 Notebook
Targus ACP50US Docking Station Logo
660 people viewed this question
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
