Question about Acer Aspire One PC Notebook
AT NIGHT I HYBERNATED ACER ASPIRE ONE BUT ON ONOTHER DAY IT DOEST TURNED ON.
  • OnlyOneN
    OnlyOneN May 11, 2010
    Try unplugging it, removing the battery, then replace the battery and plug it back it.
My laptop is shutting off on its own
Might be normal. Most laptops have a "hibernate" mode to save on the battery. They go into hibernation when they are left alone for a while. You have to press the power button to wake them just like when you turn on. If you don't want it to hybernate, go into PC settings and turn it off.
Mar 15, 2015 | Acer Computers & Internet
Acer aspire will wake up when lid is opened
That is because it is set to hybernate, not just go into standby. Go to battery options and check/reset the function.
Jul 16, 2014 | Acer Aspire 5732Z-4855 Notebook
GET ACER ASPIRE ONE OUT OF HYBERNATION
Turn it off...hold the power button.
Apr 06, 2014 | Computers & Internet
My Acer Aspire 5735 doesnt turn on
try on the laptop without battery plug in, if still didn't work, you need to get a adapter replacement for your laptop
Dec 06, 2013 | Acer Aspire 5735 Notebook
Acer aspire one netbook says hybernating. How do I get it to turn back on ?
Press and hold the power button until it fully shuts down then press the power button again to turn on.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire one pav70 went into hibernating mode . how do i get it out of hibernation
It could have gone into hybernation for more than one reason.
Either it has been programmed to or the battery is low. Either way pressing the power button momentarily will get it out, if the power supply is plugged in or the battery is charged.
To remove the hybernation option, right hand mouse click on the battery icone on the desktop and change you power settings.
Hope that helps.
Nov 28, 2010 | Acer Aspire One Netbook
My acer aspire 5050 dosent start up after you shut it down and boot it up? Help me!!!
Unplug the power supply, remove the battery then press the power button 10x or more holding each press for about 10secs. Insert the battery, plug the power supply and turn it on. If it doesn't, repeat the steps. This should remove the static electricity stuck in the mainboard.
If it turns-on, set your laptop to hybernate when you close the lid so you don't need to shutdown it anymore. If it runs out of power while in hybernation, it should start again.
Apr 17, 2010 | Acer Aspire 5050-3242 Notebook
I have Acer 5610-2762. My pc now doest turn on, once i push the power button, the green light of the battery will then turn off. what would be the problem? is my motherboard defective? please help me..
this is a rare case: inside the power button there is a micro switch. and in that swich, carbon had formed. just open the front pannel of the laptop and clear it off. or else carry it to the service authority
Jun 13, 2009 | Acer Aspire 5610 Notebook
Problem with black screen
have you try to check your battery? try to put some colling fan to your laptop to avoid hybernation of your notebook..
Mar 26, 2008 | Computers & Internet
Hybernation?? HELP!
hey, its kinda hard to tell exactly without seeing the laptop, but if you could try this, its a common problem with alot of laptop batterys.
remove the battery from the laptop, usually a switch on the bottom of laptop to remove the battery.
and try running the laptop off the mains without the battery in,
alot of the time that can fix the problem if its a faulty battery.
let me know how you get on,
John
Jan 02, 2008 | Acer Aspire 3502WLCi Notebook
Acer Aspire One  PC Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
