Question about McCulloch FHH18A Electric Pressure Washer
No soap comming out of my power washer
Cannot get soap to come out the power washer when it is turned to soap
I had the same problem on the same unit. All you need to do is pull out the front tip of the gun nozzle to engage the soap dispenser. It's as simple as that, but because there is only a tiny footprint mention of this in the instructions, it turns out to be a long drawn out problem for many of us. Hope this helps.
RP
Posted on Apr 26, 2009
    Problem Solver:
  • 10 Answers
Not familiar with this model but most work on suction so unit needs to be on low pressure for this to work, usually set by turning nozzle, or you can remove lance from gun, once you are in low pressure if you still have no soap you may need to dismantle and clean valve as these can block due to a build up of soap or chemical.
Posted on Apr 23, 2009
How do I solve my problem with my pressure washer not sending soap?
Pressure washers usually will not draw soap on high pressure setting. Switch wand or set wand to lower setting. Pin hole leak in soap line can also cause problem.
Jan 22, 2015 | Craftsman 2700 PSI Briggs Stratton...
What kind of soap is used in a pressure washer
Any water soluble washing agent ... depending on what you are washing. Some are not good if you are washing siding and will get the windows wet.
Oct 10, 2014 | Simpson PS3200 Powershot 3200 Psi Direct...
How do I get the soap to work on a power washer
you have to use a large tip in order to get soap and also check to see if the soap hose inlet is open
Sep 17, 2014 | Devilbliss DeVILBISS Devap DVH2600...
How do i install my soap dispenser into the 1600 all-power electric power washer
There should be a 1/4" hose nipple on the pump which will connect to the soap dispenser with a 1/4" line.
Sep 28, 2013 | All-Power America Garden
How to use soap dispenser on Karcher K2.87 power washer
Also, be sure the cap is turned to the direction that lets the soap in. It has a gradation on it and if it is turned all the way to the smallest (cap fully closed) very little soap will be injected into the stream.
Apr 18, 2010 | Karcher Garden
How do I turn the soap on my mcculloch power washer
Not sure about the McCulloch , but most pressure washers will only draw the soap in low pressure mode. either turn or pull the nosel on the end of the lance to switch to low pressure. I hope this helps.
Sep 07, 2009 | McCulloch Garden
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
My power washer does not let the soap come out when you turn the soap control on
You have to use the SOAP nozzle (Black Tip)  It is a low pressure nozzle.  The venturi effect prevents the psiphon under high pressure
Apr 22, 2009 | McCulloch FHH18A Electric Pressure Washer
On my karcher pressure washer, how do i get the soap to come out of the spray nozzle?
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Apr 13, 2009 | Karcher K2.26 Electric Power Washer
Washer won't turn on - door locked
If your lights wont come on it is most likely your power cord...Open the back up by removing the Three screws in the back and check your power cord. I checked my cord and the person that installed the power cord installed it incorrectly and the metal wheel ate its way through the cord from rubbing against it over time hince the reason for the main breaker box triggering. If you need more help and dont want to spend a bunch of money you can email me at cct776606@msn.com I removed the top and found the problem. check this first before you call out a professional!
Apr 05, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
McCulloch FHH18A Electric Pressure Washer Logo
2,797 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
