Question about E-Machines eMachines Desktop PC
No sound @all .i have all the speakers that came with model T5026,desk top,windowes xp,sounds card, drivers all say thet are working.not even system sounds work.
  • Dick
    Dick May 11, 2010
    Go into your Control Panel and then go to Sounds and Audio Devices. Is the "Muted" box checked? Is there sufficient volume? Click the Advanced button. Does it show the proper speaker setup?
  • Dick
    Dick May 11, 2010
    What have you done so far? Are the sound card drivers installed? Sound device working properly according to device manager? Sound muted? Speakers connected? Speakers plugged in? Computer on?
    What operating system? Need more information.
  • 3,866 Answers
Open up the sound properties and check to see if it got muted, also make sure your plugged into the right port it is usually green. You did not say if this was new,used,given to you or otherwise. if you bought it from somebody check to see if they did not put another sound card in as well. So check to see if everything is not muted then check your cable again make sure its in the green hole. All else fails a new sound card for this would run you around $35-40 bucks at Frys.com
Posted on Apr 22, 2009
I have a used dell desk top.I bought Logitech comp. speakers and ive enjoyed listen to some music on utube,until the other night. The sound went totally out! Thinking it was the speakers, I unplugged...
Hi
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
  • Ensure Volume is not in MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
  • To confirm follow next step or ROLL BACK THE DRIVER
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx For another check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). So please go there website>supports>download For download Suppose, you need driver for, ASUSK8V-VM
http://support.asus.com/download/download.aspx?SLanguage=en-us Product =Mother Board So Series = (Socket NO.eg. 754etc.) So Model = (Model no will beK8v-vm) And please select the O.S (XP/ VISTA / WINDOWS 7) version of the drivers that matches yourP.C and search. Now you can download easilyone after one. Hope it will help you.
Feb 23, 2011 | Dell Dimension 3000 PC Desktop
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
Sep 09, 2008 | M-Audio Audiophile 192 Sound Card
Soundboxen do not work how can i find the drivers for it and how to installed it
No driver is needed for the built-in speakers to work. The built-in powered speakers work the same as a desk top powered speakers system.
You just need to ifind out if it is the amplifiers in side the monitor are bad or it is the sound card problem in the PC.
Feed the monitor with the sound source such as the MP3 player to see if you can get any sound from your monitor.
If it does not work then the problem is inside the monitor, but to have it repaired will be to expensive, you will be better off spending the repair money on a good set of powered desk top speakers system instead.
Please leave rating if it helps.
Jan 05, 2011 | HP Pavilion F1523 15" LCD Monitor
On one of our macbooks the sound is grayed out and can not get it to work even after going into system preferences. the mute button is grayed and can not uncheck it
if you are using windows xp take device manager to get device manager right click the computer icon on the desk top take properties from the click hardware click device manager click the sound vedios and game controller iexpand it by clicking the " " you will find the detailes of the drivers installed if the sound driver is marked yellow uninstall it and load the drivers once again if the drivers are alreadly installed correctily check the male in conected to the speaker socket of the mother board check the volume contol wether any of the indicators is muted if the problem still presits then the problem is with the audio sockets and the audio ic if its a addon card replace it and check
Sep 27, 2010 | Apple Computers & Internet
The sound disappeared on my computer after a new hard drive was installed. However the sound returned when I altered the green sound cable to a different socket at the rear of the tower. Within two days it...
if you installed a new hard drive.. did you also installed windows on that new hd? if you did.. you may need to also install the sound card drivers.
the sound from your speakers depend on the sound card on your computer, and the sound card works only if you install the drivers that are specific for that sound card/computer. if you need help finding the drivers post back you computer specs (model, brand etc) and operating system and we'll help you find the drivers that may need to be reinstalled.
Mar 26, 2010 | Microsoft Windows XP Home Edition
No sounds
perhaps you don't have the sound card installed. check your drivers, control panel > system > hardware > device manager. search the sound card, if you can't find him he must be in the unknown devices. if you have a drive cd use it, otherwise you'll have to gogle you sound card driver.
Apr 22, 2009 | E-Machines eMachines Desktop PC
Usb speaker drivers
can u give me the model no of your sound card or chip no of your sound card
Sep 23, 2008 | Microsoft Windows XP Home Edition
Dell Desk top siund issue
Yes, it could be mother board or bad speaker wire. Or get another sound card and have someone install it for you and load the driver. again, If you have the driver for that old sound card, remove and install it again.If the sound card is on the mother board, go to the manufacture and download the driver.
Good luck
Jun 19, 2008 | Dell A525 Computer Speakers
About sound card
Try this , Plug in your speaker to your desire sound card. If it is BUilt in Maybe AC97. If is an add-on then you plug it on the add-on sound card.
and then go to control panel ..see pictures,...
4d551af.gif On the default device change the or select the device you are using and then click OK. Just do this incase you have multi device.
melnavz
Mar 06, 2008 | Edirol UA-4FX External Sound System
Speakers are not being recognised
i would like to know if your on board soud or sound card is not being recognized by your system? as far as i know speaker will not work if your sound device driver is not installed. so maybe theres nothing wrong with your speakers. try to go to my computer properties go to system device hardware and see if there is an yellow exclamation in your sound device. if there is, update the driver using the provided cd from your motherboard, if its on board sound device. but if its a sound card, update the driver using the cd provided from your sound card. but if your sound device is ok and there no yellow exclamation, probably you hooked your speaker connector to the wrong jack. it should be the color green one. try and good luck
Jan 20, 2007 | Generic Memory 2-Piece Amplified...
E-Machines eMachines Desktop PC Logo
80 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
