Question about Maytag PYE2300AY Electric Dryer
Coin-operated dryer won't turn off at end of cycle.
Coin-operated dryer keeps running and won't turn off at the end of the cycle. I have one washer and one dryer for my tenant to use, and can't afford to replace the dryer. Is this something I could fix myself? Thank you for your help. Rob
    Genius:
  • 1,198 Answers
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Posted on Apr 22, 2009
My dryer quit heating and at the same time does not stop at the end of the cycle. Just keeps running. Is there something I can do to fix this problem?
If its on automatic cycle the timer won't advance if theres no heat. It will advance on timed cycle, though.
Sep 21, 2011 | Kenmore Dryers
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
How can I adjust the run time per $1 on my maytag coin operated dryer. I would like it to run about 15 minutes per $1. Now is runs about 45 minutes on one $1.
Download this manual:
http://www.fowlercompanies.com/servicemanuals%5CMDG16SERVICE.PDF
The mechanism adjustments start on page 20. Note that the maximum number of slider cycles is 3. If you have a PD coin drop model the Max you can get is $0.75 per load I would have to assume that a different coin op mechanism may have to be used or one that will accept 2 coins per cycle for 2 cycles. On non PD models you can adjust the slots for as many as 4 coins per glide / slider cycle.
Thanks for choosing FixYa.
Kelly
Oct 20, 2010 | Dryers
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Maytag PYE2300AY Electric Dryer Logo
670 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
