Home | Canon | imageRUNNER 2200 Black and White Copier | What drivers are nee...
Canon imageRUNNER 2200 Black and White Copier
Problem for Canon imageRUNNER 2200 Black and White Copier
What drivers are needed to work a canon imagerunner 2200?
By kerflasko on Apr 22, 2009
I had to re-install windows on my computer, and I am unable to print from my computer. I tried installing the drivers from the canon website but I am still unable to print.
Comments:
Apr 23, 2009
- I did not do anything with the IP address
The printer/copier is connected to a network
Clarification Request
Posted by mortimer163 on May 12, 2009
If you enter its IP address in a browser, do you get its Remote User Interface (RUI) page?
Posted by eric400 on Apr 23, 2009
did you set the ip address on your computer back to what it was?
Posted by rjf388 on Apr 23, 2009
did you install PCL Driver or Post script???
Posted by iservice on Apr 23, 2009
Your copier,is it connected via network or local connection?
Solution #1
posted on Jul 24, 2009
Not Rated)
mdgm
Rank: Guru  Canon Expert
Rating: 89%, 22 votes
Could you print before reinstalling Windows? I assume you could in my answer below.
Try pinging the copier from your computer. Go to Start > Run > CMD > ping 192.168.0.5 - t
Replace 192.168.0.5 with the IP address of your copier.
Open the RUI as suggested above e.g. http://192.168.0.5
Can you use Canon Network ScanGear Tool? (Google it, it's freely available from Canon website and comes with user manual).
Make sure that your copier has the same IP range (first three numbers out of four for IP address are the same) as your computer and that the subnet mask's are the same e.g. 255.255.255.0.
Go into Additional Functions > System Settings > Network Settings > TCP/IP Settings > IP address to check these on the copier. Make sure DHCP is off (DHCP box should be filled with white, not filled in with black)
Where the network cable is plugged in can you see two lights coming out through holes? Move your head, they may not be immediately visible. If not then the network card isn't working.
Have you tried hooking up a laptop to the copier via crossover, changing IP address settings on both copier and laptop and seeing whether printing works that way.
Try turning off firewalls etc and see if printing works. If turning off firewall fixes it, turn it back on and add the copier's ip address as trusted.
Have you tried changing ethernet cable, seeing whether you can print from another computer on the network etc. If it works from another computer on the network you could share the printer or check how it's setup on that computer and copy the settings.
Set up the printer as a local printer. Set up a TCP/IP port with the IP address of the copier and use the PCL5e/PS drivers. If using PCL5e select print as image in the settings and if options installed are not immediately recognised press get device status, change settings as required. Set output paper size as A4, Legal or whatever you want not "Match Paper Size"
When you print check the copier to see if an error comes up or anything. If it comes up with an error to load paper select the paper tray you want and it should print.
If you couldn't print before reinstalling Windows do the following:
Press the counter check button. Near the bottom of what comes up you should see 2200(2200N). If you don't see the N then it's not networked properly.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Look at BOOT-ROM, it should have a N at the end of the number. There should be a number for PS/PCL. If there is no number for PS/PCL get a tech to come and reload firmware so you can print.
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 2200 Black
Questions and Unsolved Problems for Canon imageRUNNER 2200 Black
Do you recommend Canon imageRUNNER 2200 Black and White Copier?
Answer
Answer
fellowes c220 shredder jammed-- got some of it loose- now can't see it jammed document or get... (More)
Answer
How do I edit people in the Ricoh 3260C for scanning items?
Answer
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer... (More)
Answer
My Canon imageRUNNER 2200 won't print envelopes. How can I get this function to work?
Answer
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageRUNNER 2200 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
