Question about ATI PowerColor R92P-C3S RADEON 9200SE PCI 128MB DDR Video Card with TV-Out, DVI, VGA, DirectX8.1 (Re... Graphic Card
Direct X 9.0 c Cant be installed
When i try installing Direct X it just take 1 second and writes that Direct x Has been installed but when i try running a game which needs it brings me error that I don't have Direct X
  • 49 Answers
Uninstalling and reinstall direct x may be work out and " do not forgot remove from regeditor "
to know how to remove
https://www.youtube.com/watch?v=fsKgxOXW_QA
Posted on Apr 25, 2013
  • 519 Answers
To determine what version of direct x you have installed, click on START- RUN then type in the word :"dxdiag" in the run window. This will bring up a direct x diagnostics tool which will display the direct x version near the bottom of the page.
Determine which version you have to narrow down the possible errors on your system and games.
Regards,
Graemevm
Posted on Apr 22, 2009
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
Burnout Paradise The Ultimate Box's Installation is still installing Direct X 9 on my PC and it's been ONE HOUR. Did the installer freeze or something ?
Yes it did freeze try reinstalling the game it will fix that in most cases or you can directly download Direct X 9 and install it separately.
Aug 10, 2013 | Video Game Consoles & Games
Im trying to play a game but it cant because it shows "no d3d drivers with hardware acceleration found".i had played that game before but ever since my cdrive got corrupted i cannot play it
For some reason your CD drive has corrupted your Direct 3D drivers. Re-install Direct X 9 should fix the problem. I have written a tip explaining the process here: http://www.fixya.com/support/r6835435-d3dx9_37_missing
I have had this problem too when I first Installed a GeForce FX5200 into my system back in the day, it came down to a corrupted and out of date Direct X.
Dec 21, 2010 | Computers & Internet
When i last install Adobe Photoshop its ok... but after i reformat and try to install its ok also... but when i run... IT says Direct3d not supported... on the last reformat the directX is working fine...
It's important to let me know the operating system installed on the system with the system configuration. I will be glad if you can at least reply my post with those info.
I guess you are running windows Xp with the chipset which doesn't support Direct X 10 or newer version. Or in other words, windows vista or windows 7 with incompatible chipset for directX newer version.
First uninstall the currently installed DirectX and reinstall Direct X 9. You have to uninstall the currently installed direct x properly, and it's also important to clean the registry after it's uninstalled. After it's removed, restart your computer and reinstall Direct X 9. That'll definitely fix your problem.
If you need my further help, let me know with the details i've mentioned above so that I can help you better and with easiest instrucitons/methods.
Good luck.
Thanks for using FixYa.
Aug 30, 2010 | Adobe Photoshop CS for PC
Hi, i have a program that requires driver support for direct x 9
The problem is your on board video on your laptop only supports directX 8 then DirectX 9 will not install or run on yor laptop. The directX software from microsoft will detect if you computer can run it or not. And being it is a laptop you cannot update the onboard video to support directX 9 or higher.
Sep 05, 2009 | Battery Technology for Acer Travelmate...
Cant find d3dx_dll at my laptop built-in video card
Install DirectX.
http://www.microsoft.com/downloads/details.aspx?FamilyId=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
If you already have DirectX 9 installed, grab the missing DLL from here (the newest ones are at the bottom):
http://www.toymaker.info/Games/html/d3dx_dlls.html
Place them in c:\windows\system32
Apr 14, 2009 | Acer Computers & Internet
Parental lock
1) Try P-Lock and pasword "0000"
2) Turn TV off and unplug from wall outlet for 30 seconds
3) Check p. 9 and other relevant sections of your user manual.
4) Call Insignia at 1-877-467-4289
May 26, 2008 | Insignia LCDTV26 26 in. Television
Zen Microphoto MTP drivers not installing, stuck in loop
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Jan 12, 2008 | Creative Labs Zen Micro MP3 Player
Computers & Internet Logo
160 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
