Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Panasonic LCD I cant find the model # at this point but in the front it has 1080i which I believe has to do with the resolution. Myn problem though is that when I power it on the green led in fron start to blink and it chirp two time but never powers on Please help Thanks
    Genius:
  • 1,694 Answers
Please supply model number off back of set......T.
Posted on Oct 23, 2007
SOURCE:
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.
Let me know if this fixes the issue.
Regards,Suhail
May 11, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
I have a sony 3d tv model xbr-52hx909 how do you change the resolution from 1080i to 1080p
The resolution is controlled by the video sources, you do not adjust it at the TV, if you feed it with video sources that is 1080i it will display 1080i.
I hope that will explain how it works.
Apr 02, 2011 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
I need to reset the screen resolution from 480 dpi to 1080 dpi
The TV does not have resolution setting adjustment, it works the same way as the PC monitor which the resolution is done on the PC, same for TV. If you feed it with 480p signal, it will display 480p, if you feed it with 1080I it will display 1080i. The video source dictates the TV display resolution.
What kind of video sources are you feeding the TV with?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 15, 2011 | Insignia 42" LCD Flat-Panel HDTV
Panasonic Model TC - 32LX60 can't switch to 1080i again manual doesn't tell me
The resolution is not set at the TV, the video source sets what the TV will display, 720i/p in = 720i/p display. May be you are talking about the aspect RATIO setting, 16:9, 4:3, zoom1, 2, 3.
It works the same as youe PC monitor, the resolution is set at the PC not at the monitor.
http://s807.photobucket.com/home/budm/allalbums
Jul 17, 2010 | Panasonic TC-32LX60 32 in. LCD Television
When I set resolution at 1080i .why does it change
You need to post more information about your TV. A model number would help
Jul 02, 2009 | Vizio SV470XVT 47 in. LCD TV
I dont know if my lcd tv supports 720i, 1080i, or 1080p
Sorry. It does not. 480i and/or 480p.
http://www.generalmanual.com/Televisions/Sanyo-CLT1554-STEREO-LCD-TV-EDTV-Monitor.htm
Picture Resolution: 1024 x 768 (XGA);NTSC (480i) EDTV (480p)
Dec 24, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Qualia 005 compatibility with Blue Ray, AND where can I find a stand and a wall mount?
I may be sticking my neck out on this one, but I don't believe there is a way to improve the input resolution. If I'm right, the issue is not related to a firmware upgrade but the hardware design of the board and IC's on them. I have the same issue with a Toshiba 1920 x 1080 resolution TV.
The best you can do is to set the blu-ray to output at 720P which is actually higher resolution than 1080i. Here's why. 1080i is actually two fields of 540 resolution interlaced or put another way one 540 image overlaying a second 540 to make one complete video frame.
Still you make the call as to which one looks best to you
Apr 11, 2008 | Sony QUALIA 005 46 in. LCD Television
Only get 480p
Hi.
Your friend is wrong you will get same resolution of 1080i whether you use component or Hdmi.
But you will need a high def input to tv in order to get this resolution EG high def cable box or satellite.
http://dysonmanuals.llc.nu/
Mar 24, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Daniel
It'll still be 480i, it'll just work on a 1080i input now. You can't make HD out of a non-HD source.
Geno
Jan 24, 2008 | Televison & Video
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
