Question about Hoover F5832-910 SteamVac Supreme Vacuum
Attaching the attachments
I can't figure out how to attach the stair cleaner to the cleaner
    President:
  • 1,673 Answers
Take off the brush that is on the end of the hose, then attach your stair cleaner on the end of the hose.
Posted on Mar 13, 2008
SOURCE:
BRUSH WON'T TURN ON THE STAIR ATTACHMENT
A modern cylinder type cleaner often uses a stair attachment with a rotating brush bar that is driven by a turbine driven by the air passing through the attachment. If the brush bar turns easily by hand then it isn't jammed and the fault could be related to a loss of suction reducing the amount of air being consumed by the vacuum.
Try servicing the cleaner; emptying it, cleaning/replacing the filters and ensuring the internal and external hoses are completely clear,
Jan 10, 2017 | Vacuums
Tip
How To Attach Carpet Shampooer To Your Kirby Generation 4 (G4) Upright.
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 4. The only major difference is that the Generation 4 does not have the lever that extends out to turn the belt to off. On the Generation 4 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 4 (g4) Vacuum Cleaner:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
on Mar 21, 2010 | Kirby G4 Bagged Upright Vacuum
Tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
Chris J.
on Mar 21, 2010 | Kirby Generation 3 Bagged Upright Vacuum
How do you put on the attachment hose to clean stairs
Assuming the rug nozzle is currently attached, lift up the headlight hood. Twist the belt lifter (black plastic square) on the rug nozzle counterclockwise to remove the belt tension. Then pull the accessory lock up until the rug nozzle comes loose of the Power Plant. You will notice two hinges at the bottom that hook on the the Power Plant's attaching bar. Gently lift up the rug nozzle to unhook it from the attaching bar.
Now your Kirby is naked. You will notice two small hooks on the hose attachment--hook them over the attaching bar, place the end of the hose attachment firmly against the Power Plant, then push the accessory lock down to clamp the hose in place.
You are now ready to use your Kirby with the hose attachment.
May 20, 2010 | Kirby Heritage II Vacuum
Attach furniture/stair cleaner ?
Please look at the user manual at the following link:
http://www.hoover.com/pdfs/manuals/F5871900.pdf
It is for a similar Hoover Steam Vac model.
Oct 30, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
How do I attach the stair cleaner attachment
  1. remove recovery tank lid
  2. remove tank duct from front of tank
  3. slide flat end of hose into slot where tank duct was<open side up>
  4. place tank lid back on
  5. open water hose door on hood
  6. push waterline onto spickett
  7. clean your stairs.
best of luck
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
How do I attach and use the shampooing attachment so I can clean my couch?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=579274
How do I attach and use the shampooing attachment...
Posted by rottylvr on May 08, 2008
I have a Kirby Vacuum and Carpet Cleaner that I know how to use, all except the attachment that I am not sure about. I am not sure if it is a vacuuming attachment or can I attach it and use it to clean my couch, I do not have the user guide for my vacuum as I got it from my son's ex girlfriend in lieu of money she owed me. It looks like it should be used for shampooing things like stairs and furniture, but for the life of me I cannot figure it out! Can you please help me? Tell me how to attach it if it is supposed to be used to clean stairs and furniture or tell me where I can find the user guide to look at and see how to use it......Oh by the way I have a 160 pound rottweiler that tries to live on my furniture and my couch is in desperate need of cleaning, this is my only day off and I have spent all day cleaning carpets due to my dog and would love to clean my couch before returning to work and putting my dog in the back yard now that it is warm enough for him to be outside all day.
Thanks,
Desperate to reclaim her couch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. Also, there is a separate shampoo head that will be in the owner’s manual, you remove the vacuum head and bag assm and attach the shampoo head, make sure you use genuine Kirby shampoo for the carpet. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F5832-910 SteamVac Supreme Vacuum Logo
218 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
