Question about Maxent MX-42VM 42 in. Plasma HDTV
Watch tv through antenna
Toshiba 37hlc56 I can't figure out how to get the the antenna to work on my tv through the vcr.i thought i had everything hooked up right, but it wont let me turn the channels, and it has a blue screen on all the modes.and what mode do i need to be able to watch tv through ant.
Mine turns itself on as soon as its plugged in,goes to just a blue screen and buttons do nothing,no menu,no volume,just a bright blue screen,whats up with that?
Posted on Dec 22, 2007
SOURCE:
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
I have separate dvd player and vcr, how do I hook coverter box up
It took some time, but I finally have this figured it out so everything works.
I have the same setup, but I had one additional piece to the puzzle that I had to figure out. I have an older TV and use and antenna, but had to buy an Audio/Video RF Modulator a couple of years ago to use my VCR & DVD player with the old setup.
Get yourself an Audio/Vido RF Modulator (you can pick one up for about $20-30).
Connect the TV to the RF Modulator.
You should have 2 connectors for your antenna. Connect one to the converter "To Ant" and the other to the RF Modulator.
Connect the convertor A/V cable to "IN" on your VCR.
Connect the cable from converter "To TV (RF)" to "UHF/VHF from Ant" on VCR.
Connect the VCR "OUT" cable to the RF Modulator.
Connect DVD A/V cables to A/V input on VCR.
Your TV should be set to Channel 3 (or 4, depending on your setup) and depending on your "input" connections, you should be able to view vidoes from VCR like this and DVD by changing the input (the button should be on your VCR or other remote). For ex. my input changes on my VCR from channels, to L1 & L2. My converter & VCR play on L1 and DVD's play when I change it to L2.
Now, I just have to figure out how to add the converter box to my universal remote. :)
Feb 14, 2009 | Insignia Digital-to-Analog Converter for...
Don't know how to change from cable to antenna
on the back of your set
there may be a small switch someone with 2 or 3 different options
Jan 20, 2009 | Sony KV-24FV12 24" TV
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Maxent MX-42VM 42 in. Plasma HDTV Logo
330 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
