Question about Nortel Meridian M7208 Corded Phone
Meridian M7208 Phone-Only 2 lines are working
Power went out and now only line 1 and 2 are working. Line 3 and 4 do not work for incoming or outgoing calls.
I tried looking through the menu, but didn't see any options that apply.
There are 5 of the same phones using the same system.
Please help!
Sounds like it might be a telco problem. Do lines 3 ,4 work on the other phones?
Switch lines 1 and 3 to see if the problem changes.
Posted on May 07, 2009
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
All 3 phone sets have no dial tone and arrows to each of the 8 lines are flashing. The caller ID window is blank - no info. The telephone line is working as I am receiving faxes - help?
This usually means the PBX unit is booting up.
Try power cycling the PBX unit. If that does not work, there is some hardware failure on the PBX.
Feb 28, 2011 | Nortel Meridian M7208 Corded Phone
No dial tone
try another M7208 phone using the same connection including the same line cord, if that phone works then the first phone is bad, if not then look for trouble at the outlet or line cord
Dec 08, 2010 | Nortel Meridian M7208 Corded Phone
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
Meridian M7310; just installed replacement phone (used); line 3 disconnects when answered. Lines 1 and 2 work fine. They are in the loop. Line 3 is dedicated fax incoming but can be used as outgoing phone.
Normal 0 Hello, Gary.
Disconnect power and cables from all phones and faxes on the line 3. Wait 15 minutes and reconnect the line again, one at a time. See if the Meridian works. If not, it could be faulty.
Hope this helps.
Feb 01, 2010 | NorStar M7310 Corded Phone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
Meridian M7208 phone
You can unplug the phone system to reset it, plug it back in and then turn off that forward rule.
Nov 23, 2007 | Lands Phones
Nortel Meridian M7208 Corded Phone Logo
396 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
