Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Dead Control Panel - F7
I have a similar problem that DeadOven posted on 1/22/07, but my oven would automatically turn on the broiler, beep until I hit the clear button. It would repeat this several times then the code F7 would appear. Now the panel is locked. I wassn't sure what Krazytech meant by the ribbon cable. Where is this found and will this solve my problem?
  • 833 Answers
Easiest fix: open the circuit breaker for the stove...wait a minute and reset. Should get you going.
Posted on Dec 13, 2007
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Beeping and F7 when cleaning
F7 stuck keypad
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
May 12, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Whirlpool oven
When I had a similar problem, the door wouldn't unlock even after unplugging, waiting 30 minutes, and plugging the oven back in. I finally had to manually unlock the oven by turning the lock latch motor myself.
Here's a good page that describes what the lock latch motor looks like and where it's located. Of course, there is 220V current running around inside there, so please unplug before removing the back access cover and put it back on before plugging the oven back in.
My symptoms:
  • Oven failed to complete auto-clean cycle.
  • Oven started beeping; control panel showed FSE 1
  • About a minute after plugging in, oven started beeping and displaying FSE 1 again
Once I unlocked the door manually and plugged back in, the oven started behaving normally.
Jan 01, 2008 | Whirlpool RF368 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
