Question about GE 13TVR60 Combo
AIWA VX-T1420 Setting Channels
I cannot set channels. I do not have the original remote but have tried unsuccessfully to program a Univeral 3 in 1 Remote. The remote sensor on the TV appears blank (should it be lit up ?)Is there any way I can set the channels ?
Have aiwa VXT1420 unable to auto tune the channels. please guide me
Posted on Jul 26, 2011
    Genius:
  • 1,153 Answers
No it should not light up. If you can not go into menu and add channels manually or auto program. Then you will have to get a remote to work. You could order original remotecontrols.com.
Posted on Sep 23, 2007
How to program phillips univeral remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 04, 2014 | Philips Phillips SRP1103/27 3-Device...
No remote. How do I reset the menu or channel programming? Using sat box, but can't get the TV to channel 3.
You best bet really is to locate an original and not a universal remote for the set
Apr 08, 2012 | Televison & Video
I lost the remote i bought n rca programmed tv only works with volume and channel changing. i have cable and i want to add channels. i need to access the menu
U can't access menu of the tv with the univeral remote.Only with the original remote.Try website like Remotes.com to buy an original remote.
Oct 02, 2010 | Televison & Video
Remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Dec 15, 2009 | RCA Universal Remote Control
I hv PANASONIC COMMERCIAL TV - MODEL CT 2522 HE. I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME...
I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME CHANNEL.SOME OF THE CHANELS SKIP,I want all channels to be programmed..pls give the solution
Nov 24, 2009 | Panasonic CT25G7 25" TV
How do I open the menu to program the channels without a remote. I have a sharp TV made in 1989 model #25NV88. I have lost the original remote and have attempted several different univeral remotes, but...
Buy,have the same or an exact remote with this web.site.1-800-remote factory original.
Not possible open the menu,if the tv don't have it in the front of the tv or tside.The IR board very rare to burn,not possible.
Aug 28, 2009 | Televison & Video
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
I lost the original remote to my 27'' television
very sorry for that but you can be changing channel manually on the tv channel buttons, if you sweep on all channels you can go to AV from RF channels, that is before you buy a remote.
try to buy your remote from
www.ebay.com
Apr 28, 2009 | Televison & Video
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Channel selection woes continue!
Sorry but your going to need to get an original remote from a friend or relitive to program this set. They sell rca universal remotes for 10 to 15 bucks that will work for you too.
Sep 18, 2006 | RCA F27628 27" TV
GE 13TVR60 Combo Logo
490 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
