Question about Whirlpool Washing Machines
Whirlpool washer pours water on right side
As the washer starts filling with water within 20 seconds of filling, water begins pouring out the side. I have checked all the hoses, no cuts or holes. It is wet around the pump and motor connection,the rubber casket between them is torn. Is the pump bad or will a new casket fix it?
  • Whirlpool Master
  • 3,361 Answers
The pumps on these washer wear out over time and leak.
While replacing the pump, you should replace the direct drive coupling also. That is part of the torn rubber gasket you are referring to.
This video will show you access to the parts.
Posted on Apr 22, 2009
In 3 buckets, two Buckets filled with 20 litres of water, first- 19 litres capacity(max) second- 13 litres capacity(max)-Filled third- 7 litres capacity(max) -Filled i need to fill 2 buckets with 10...
Assume the following:
B1 = 19 litres capacity
B2 = 13 litres capacity
B3 = 7 litres capacity
B2 and B3 are full. The answer is:
1. Pour 2 litres from B3 to B1
2. Pour 8 litres from B2 to B1
3. Pour the remaining 5 litres in B3 to B2
Another answer:
1. Pour 10 litres from B2 to B1
2. Pour 7 litres from B3 to B2
In both answers you will get 10 litres in two buckets.
Rate if this answer was helpful.
Thanks
Oct 22, 2010 | Computers & Internet
Leaking water
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
May 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer seems to be leaking during spin cycle.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damged, must be replaced. The following link explains how:
repairclinic.com
May 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer won't fill up with water...it is about 7 years old. The water acts like it is filling up but just keeps pouring water in and out.
it is problem it is just aweak inlet pressur so check inlet water from start path from wall untill the inlet filter >
good work !
thanks
Jul 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell
probaly a good wash with chlorine bleach..fill tub with hot water pour 2-3 cups bleach let agitate for few mins stop machine and let set 20-30 mins restart and let finish cycle ..to head of future problem leave lid open between uses
May 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water pours from soap dispenser when starting cycle
id remove the top of the unit. 3 screw along the rear top lip. annd check the hose leading from the nto the tub, sonds as if its clogged/kinked
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
