Question about TruTech PVS12701 Portable DVD Player
Wire in plug came unsodered
The plug for my dvd player the wire came unsodered in the plug
    Problem Solver:
  • 11 Answers
If you are near to sony shop return it immidetly and explain the ploblem all sony dealer and wholesallers know where he or she can get quick costomer servace free warrant cover one year if you are above 1yr servace is not free
Posted on Apr 23, 2009
Power ON DVD, horizontal lines running on the TV screen. How do I get the horizontal lines to stop running and for me to view the screen to possible reset the DVD player.
Check video plugin to see if connect good on both tv and dvd player. You might try unplugging and re plug. If that doesn't help you might try another plug wire not sure if you have rca or HDMI plugs.
May 14, 2015 | Jwin Electronics JD-VD138 DVD Player
How do I connect the DVD player to my tv? My last DVD player had a place on the back to be able to hook in the cable along with the color wires. This DVD player does not have a place to hook in the...
What colour wires does the new dvd player have? The colours correspond with the socket that you plug them into. If your new dvd player only has yellow red and white cables then that is all you need. if they are red blue and green then you will also need to plug the appropriate audio cable into the dvd player. If you need more help please tell me the model of dvd player and the model of tv
Dec 25, 2010 | Televison & Video
Where do the blue, red, and green wires that plug into the DVD player plug in? Are they supposed to plug into the TV set?
it is known as componant input & out put.if your tv has component input then connect three rca wires from dvd to tv and change input mode to component.if your tv doesnt have compo in then u can connect it to v in yello wire ( only one wire)
Jun 04, 2010 | Samsung DVD-V4600 DVD Player/VCR
Record dvd player to dvd recorder to tv
take the dvd player plug white,yellow & red (line out) & plug these 3 wires into L1 or L2 in on dvd recorder (note on the recorder you must switch the channel from ch3 to either L1 or L2 to record from the player)....... now place the dvd you want to record in player & a blank dvd in the recorder.......press record (recorder)/ press play on (player)
feel free to rate the help
May 24, 2010 | Samsung DVDR120 DVD Recorder
Our remote won't work any suggestions
change the battery? alot of times the battery is corroded or unsodered take apart and u will see i fixed many remotes even car remotes for alarms with seeing is everything just pry apart but look for screws first. let me know but its not the unit
Apr 27, 2010 | Farenheit MD830CMBG Car DVD Player
My Memorex MVD2042 DVD player isn't getting any power
If you are plugging your DVD Power Plug into the TWC Box. Unplug it and plug it into a 'known' hot socket, (wall..con strip.etc.). Ensure the AC plug is inserted fully into the DVD player. The TWC AC connection may be disabled.
Read Ya,
z
Jan 01, 2010 | Memorex MVD2042 DVD Player
How do I conenct player to tv
  1. Yellow wire is picture and the 2 red is sound
at the dvd player plug in the picture wire by av out, at the tv plug the yellow wire in av in.
The sound is the same sound out at the dvd player look for a L R this means left and right at the tv there should under av in next to the picture wire you pluge the soun in
hope this is clear to you
Jan 04, 2009 | RCA DRC220N DVD Player
Plug into Tv?
In your accessories kit that came with your DVD, you should find a cable with a red ,yellow and white RCA ends. at the other end is a 1/8 inch Tip /ring/sleeve plug. Insert the plug into the output of the DVD. Insert the yellow wire to the same color coded INPUT of your television, insert the red and white wires to the Audio input on you TV. Your DVD should be sending the signal directly to your TV. hope this helps . if it does , vote.
Dec 22, 2008 | Mintek MDP-1760 Portable DVD Player
My jensen dvd player mvb85
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Feb 06, 2008 | Jensen 8.5" Overhead DVD Player Package...
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
TruTech PVS12701 Portable DVD Player Logo
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
